Author Topic: HELP - Installing an aux port to standard RCD300 without 6 disc changer  (Read 4861 times)
Offline daiwill95
Was just wondering if there was anyway I could fit an aux port or somehow plug my phone (ipone 5s) into my cd player? Or would i have to buy a whole new one?
I have the standard vw single din cd player at the moment, sorry i dont have model number... but comes in most standard GTI's.
If someone could answer this it would be a massive help!
« Last Edit: January 26, 2015, 07:40:11 pm by daiwill95 »
Offline daiwill95
Re: HELP - Installing an aux port to RCD300 with single disc changer
« Reply #1 on: January 26, 2015, 07:39:37 pm »
I can confirm the cd player i have at the moment is RCD300 but it doesnt have the 6 disc changer so now is there anyway i can ad a port to play song from my iphone 5s or an aux port ?????????
Offline Tim62
Re: HELP - Installing an aux port to standard RCD300 without 6 disc changer
« Reply #2 on: January 27, 2015, 09:36:30 pm »
Yes easily done, you can get a box to plug in the back which appears to the headunit as a changer with a single cd in it... then plug an aux cable into the box and route it to your ashtray, glovebox etc. You just press cd twice to select the changer.
Search ebay for "rcd300 aux" and you can't go far wrong. I got the Connects2 one but there are other options.
Offline killsta
« Reply #3 on: February 09, 2015, 03:02:49 pm »
Does anyone know if you can still use the single cd slot whilst the aux cable is plugged in? I.e. Having an aux cable doesn't disable the slot cd drive?
Offline J60RWN
« Reply #4 on: February 10, 2015, 12:24:27 pm »
I had a connects2 unit in my last car but looking to have the aux in the GTI. Searched rcd300 aux on ebay and one of the items it brought up is the link below, would this work?
http://www.ebay.co.uk/itm/Switch-Plug-USB-AUX-Cable-For-VW-Volkswagen-Touran-Tiguan-RCD510-RCD300-Nice-ite-/351256547092?pt=LH_DefaultDomain_3&hash=item51c8858f14
thanks
Offline Tim62
« Reply #5 on: February 12, 2015, 07:53:32 pm »
Yes, CD slot still works.
thanks
That won't work with a RCD300 as it doesn't actually have an aux input (let alone an input for USB), hence you need a connects2 to convince the unit you're using a changer.
Offline killsta
« Reply #6 on: February 12, 2015, 07:56:13 pm »
Cheers Tim  :happy2:
Offline J60RWN
« Reply #7 on: February 12, 2015, 11:26:46 pm »
Thanks Tim, avoided a waste of money!
