Author Topic: Rcd 310 and Gateway question!  (Read 1050 times)
Offline Lilsaint911
« on: January 27, 2015, 10:40:22 am »
Hello !
I have a rcd 310 from Tiguan 2010 , i put it in golf 2005 the old gateway don't fit case it drain the battery so i have a  Gateway 1K0907530K serial number .
the question is does it fit to the rcd and will it solv the problem of the draining power????
Offline skard
  • -Receive: 245
Re: Rcd 310 and Gateway question!
« Reply #1 on: January 27, 2015, 10:44:42 am »
What version software is on the K?
Some of the K versions are fine, some aren't. You are better with an L or later to be sure.
Offline Lilsaint911
« Reply #2 on: January 27, 2015, 11:16:28 am »
where i can see the version??
Offline skard
  • -Receive: 245
« Reply #3 on: January 27, 2015, 01:05:41 pm »
Top right, four numbers. If you have one with a white sticker, there is an S before the numbers
