Author Topic: What brake pads.  (Read 1642 times)
Offline howie1987
  • -Given: 92
  • -Receive: 20
What brake pads.
« on: January 28, 2015, 04:47:45 pm »
This could be a bit of stupid question.
Am looking at buying brake pads for my golf mk5 gti.
I noticed there are different sizes of pads when i put my reg number in. My brakes are standard so what ones do i need or do either fit ? Just obviously the larger ones are better.
Offline BigstickytoffeeGTI30
Re: What brake pads.
« Reply #1 on: January 28, 2015, 05:08:13 pm »
Not a case of bigger ones, only one size will fit unless you want to upsize your calipers and discs. Really a case of upgrading pads and possibly discs. Pads will make the most difference, and everyone has their own personal opinion/taste/experiences.
Reading your post again on sizes offered, I found some websites offering r32 brake pads for gtis -so double check before confirming order!
« Last Edit: January 28, 2015, 05:46:54 pm by BigstickytoffeeGTI30 »
Offline howie1987
  • -Given: 92
  • -Receive: 20
« Reply #3 on: January 28, 2015, 05:58:33 pm »
Hi mate. I wasn't looking to upgrade to bigger brake kits or that. Was just when i put in my regi it comes up two different sizes of pads. So i just need the smaller pads then?
« Reply #4 on: January 28, 2015, 06:06:21 pm »
Not necessarily it depends on what they offered you, it might be the larger!
Where are you looking and for which pads?
« Reply #5 on: January 28, 2015, 06:11:34 pm »
http://www.vwspares.co.uk/product_info.php?products_id=328
I believe these are the matching OE part numbers. :smiley:
Offline howie1987
  • -Given: 92
  • -Receive: 20
« Reply #6 on: January 28, 2015, 06:17:08 pm »
It was on carpartsforless. Pagid pads.
Will check out that link above.
Cheers mate.
« Reply #7 on: January 28, 2015, 06:35:01 pm »
http://www.golfgtiforum.co.uk/index.php?topic=211145.0
Somebody with the same problem. Looks like the ones ending 138.  :happy2:
Offline howie1987
  • -Given: 92
  • -Receive: 20
« Reply #8 on: January 28, 2015, 07:33:45 pm »
Spot on cheers.
