Author Topic: Front brake disc change, advice please.  (Read 1075 times)
Offline AndyBrown
« on: January 29, 2015, 08:18:27 pm »
I'm going to change my front brake discs the next couple of days, it's not something I've done before so I'd like a bit of advice.
I've read a few bits online and I'm quite confident in doing the task. Is there anything anyone thinks I should make sure to do? Tips and advice greatly appreciated.
I've read I should copper grease the hub, the carriers and clean any sh*t that's built up.
Anything else I need to know or do?
If I remember I'll take some photos of the steps as a guide for anyone else, one of you will probably have to annotate the photos as I won't know the right names for different bits.
Thanks.
Offline AndyBrown
Re: Front brake disc change, advice please.
« Reply #1 on: January 29, 2015, 08:45:27 pm »
Also,me here's the best and safest place for the axle stands?
Offline andybon
« Reply #2 on: January 29, 2015, 09:17:52 pm »
Halfords have a good set of axel stands in for a tenner, only issue I had was getting the disk off the hub, after removing the screw holding the disk on it was well stuck on. As I didn't have a puller I just hit it with a lump hammer at the top bottom then sides until it fell off.
Probably not the best way of doing it but it worked!
How hard can it be?
Offline AndyBrown
« Reply #3 on: January 29, 2015, 09:28:33 pm »
They're not in the sale anymore, my mates got some and a trolley Jack he's lending me, saves me out laying £50 or whatever.
Offline AndyBrown
« Reply #4 on: January 29, 2015, 09:31:50 pm »
Did you use axle stands Andy? Where's the best place to put them?
