Author Topic: Mk5 Stealth subwoofer enclosure  (Read 12540 times)
Offline Jarre
« on: January 29, 2015, 11:11:53 pm »
Hi,
I recently purchased a subwoofer enclosure suitable for mk5/6 on the passenger side wheel arch.
http://www.ebay.co.uk/itm/VW-Golf-MK5-MK6-Custom-Fit-MDF-10-Sub-Box-Subwoofer-Enclosure-Bass-MKV-MKVI-/370799663953?pt=UK_In_Car_Technology&hash=item565561db51
I believe it requires a 'slight modification to the boot carpet' to fit, is anyone able to advise what this is or link me to somewhere that explains it? I can't find any instructions at all.
Cheers!
Candy White ED30 :)
Re: Mk5 Stealth subwoofer enclosure
« Reply #1 on: January 30, 2015, 12:15:08 am »
i got one in mine but a fibre glass one and it was a perfect fit
Offline Jarre
« Reply #2 on: January 30, 2015, 08:32:31 am »
Are you able to provide me with a link? I may have to purchase another one. Are you able to tell me how you have secured yours in place? Chsers
Candy White ED30 :)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=c3jn1dv8rh6cmj2bki2em1mco8&/topic,90967.msg917089.html#msg917089
« Reply #3 on: January 30, 2015, 08:56:06 am »
I have the same box it was a PITA to fit.
I cut off the car seat tether. Drilled some holes in the box and used cable ties to secure it in place. Sealed the holes with silicone. But it still did not fit well.
05 | Tornado Red | DSG
Offline Jarre
« Reply #4 on: January 30, 2015, 12:04:20 pm »
Looks more like I might be better with another alternative then...
Candy White ED30 :)
Offline Jarre
« Reply #5 on: January 30, 2015, 12:11:44 pm »
Candy White ED30 :)
« Reply #6 on: January 30, 2015, 05:14:40 pm »
mine is like this and it bolt screws into where the strap goes but I just jammed mine under the parcel shelve
« Reply #7 on: January 30, 2015, 05:20:47 pm »
Offline Jarre
« Reply #8 on: January 30, 2015, 09:04:58 pm »
Thanks for that, I will look into it!
May well be another case of buy cheap buy twice...
Candy White ED30 :)
Offline Jarre
« Reply #9 on: February 25, 2015, 11:23:18 am »
Well, I decided to buy an enclosure from visual ice, the quality is excellent, I'm really impressed! Fitting is so much better than the cheaper one, too.
My amp is under the passenger seat leaving the boot looking tidy :)
Candy White ED30 :)
Offline usmangti
« Reply #10 on: February 25, 2015, 11:54:56 am »
Off topic slightly, where are you guys taking your ignition live from for the remote wire, Dazza mentioned a fuse box job but is there any other, behind the stereo perhaps?
Offline Jarre
« Reply #11 on: February 25, 2015, 03:09:26 pm »
Mine is on the interior fuse box using a piggy back/ add a circuit fuse holder. That's the safest way to do it. See link below (may not be the cheapest price)
http://pages.ebay.com/link/?nav=item.view&alt=web&id=181548508189
Candy White ED30 :)
Offline usmangti
« Reply #12 on: February 25, 2015, 03:15:14 pm »
yep that's what dazza recommended. Can you show me which fuse you used? I assume its the fuse box in the drivers side dash.
Offline Jarre
« Reply #13 on: February 25, 2015, 03:23:31 pm »
Yeah the drivers side fuse box. The one I used was fuse number 2
Candy White ED30 :)
Offline usmangti
« Reply #14 on: February 25, 2015, 04:28:01 pm »
That is perfect thanks!
