Author Topic: GOLF TDI DSG FLYWHEEL RATTLE  (Read 7063 times)
Offline MAH
« on: January 30, 2015, 05:49:20 pm »
Hi all,
I have used the search engine at the top and have not been able to locate a lot of information regarding DSG dual mass flywheel rattle.
It seems to rattle on when idle in park or neutral or when switching the engine off. It does not rattle in drive or reverse.
Anyone with similar problems? How much would it cost to be rectified?
Do we need to change the clutch aswell when replacing the flywheel?
MAH
Offline MAH
Re: GOLF TDI DSG FLYWHEEL RATTLE
« Reply #1 on: January 31, 2015, 01:19:43 am »
Anyone with a dsg who may have had the flywheel rattle before?
Offline Llew
  • -Given: 45
« Reply #2 on: January 31, 2015, 10:28:25 am »
I had the same problem you'll need to change it 235 quid from carparts4less is the cheapest place I found to buy then I got a garage to fit for 200 or for peace of mind darkside developments can supply and fit for around 588 quid
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
Offline MAH
« Reply #3 on: January 31, 2015, 12:12:39 pm »
Cheers bud. Do you have a link for the exact flywheel. My engine is the BKD one and 2005 DSG. Did you get your clutch changed aswell at the same time?
Offline MAH
« Reply #4 on: January 31, 2015, 12:27:41 pm »
It's showing as £287 for my car plus I have to buy the bolts
Offline Llew
  • -Given: 45
« Reply #5 on: January 31, 2015, 08:06:22 pm »
Mine is dsg no need for clutch
Offline Llew
  • -Given: 45
« Reply #6 on: January 31, 2015, 08:10:40 pm »
Just checked the price must have gone up in the last fortnight
Offline MAH
« Reply #7 on: February 01, 2015, 12:36:30 am »
Showed my mechanic and he confirmed it's definetly the flywheel.
Have you had any issues after replacing it with the LUK flywheel?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #8 on: February 01, 2015, 08:23:37 am »
Bro i think mine may be on its way out as well. Ill link up with you and have a look if you want.
Offline MAH
« Reply #9 on: February 01, 2015, 10:31:37 am »
Yeah bruv, let me know when your back and we'll hook up
I heard this is a common failure on these cars especially pre 2008 DSG's
Offline MAH
« Reply #10 on: February 01, 2015, 10:45:16 am »
How hard is it to change the flywheel on one of these?
Offline Llew
  • -Given: 45
« Reply #11 on: February 01, 2015, 02:01:24 pm »
No issues at all but with it being a dsg you need someone trustworthy due to the expensive repair cost of a dsg box
Offline Llew
  • -Given: 45
Offline MAH
« Reply #13 on: February 01, 2015, 02:23:53 pm »
Did your mechanic have to remove the entire transmission to change the flywheel?
Offline Llew
  • -Given: 45
« Reply #14 on: February 01, 2015, 03:01:13 pm »
Yes
