Author Topic: Door gremelin (controller?)  (Read 1090 times)
« on: January 30, 2015, 11:12:00 pm »
I have an issue where my drivers door fails to lock when reaching the preset speed.
If I press the unlock button in the centre console & then reach that speed again (15mph?) the door then locks.
It makes a noise the 1st time but if I lower my window and try and open the door from the outside it still opens
I haven't got Vcds handy atm.  Is it a common issue/ fault?
Thanks for any advice.
Mike
Offline Orc
  • -Receive: 25
Re: Door gremelin (controller?)
« Reply #1 on: January 31, 2015, 12:54:40 pm »
I had the same issue in my eddy was driver door controller. :happy2:
« Reply #2 on: January 31, 2015, 01:42:19 pm »
Thansk @Orc. Are there many variants? So I can start shopping around. @Eddie-NL @mortygttdi
Thanks again.
« Reply #3 on: February 01, 2015, 12:00:40 am »
I assume it's eBay item; 231461232645
Offline Alzak
« Reply #4 on: February 01, 2015, 11:41:10 am »
Make sure you buy correct side as both sides have different part number.
About year ago i replaced N/S and now looks like other side is failing ...
« Last Edit: February 01, 2015, 11:42:47 am by Alzak »
« Reply #5 on: February 01, 2015, 11:52:03 am »
Was it just a case of noting the coding in the existing one and copying it into the replacement one?
Saw they are sided, cheers
