Author Topic: Caliper paint  (Read 2530 times)
Offline Gti man
  • -Given: 17
Caliper paint
« on: January 31, 2015, 05:05:42 pm »
Any one recommand brake calipers paint
at the moment I am using the halford stuff.
Everything on eBay seems to be the same
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=oeg8lgoqr16ctl6g6fhbvkvoja&/topic,19740.0.html
Re: Caliper paint
« Reply #1 on: January 31, 2015, 05:06:54 pm »
Foliatec
Offline Shoy1980
Re: Caliper paint
« Reply #2 on: January 31, 2015, 05:10:21 pm »
What grit sandpaper is required to sand down the caliper before paint? I've heard good feedback from Hammerite as well.
dansmith180
Re: Caliper paint
« Reply #3 on: January 31, 2015, 05:45:33 pm »
I've used hammerite a few times. I would recommend the spray on over the brush on stuff. You want to use as low grit as. You can get so the paint adheres better, anything above 1500 I've found is pretty pointless.
Offline jedi-knight83
  • -Receive: 41
Re: Caliper paint
« Reply #4 on: January 31, 2015, 06:02:20 pm »
I wire brushed mine and then used hammerite smooth and brushed it on. When doing them on the car i think brushing is better. If your removing them and taping up the bits you don't want paint on etc then obviously spraying will be a much better finish. Also painted the hubs and the stone guards black.
Offline mk5-beast-91
  • instagram: subarukid24
Re: Caliper paint
« Reply #5 on: January 31, 2015, 06:40:26 pm »
i used etech high temp paint and lacquer. worked a treat. i wire brushed the old paint off and cleaned with brake cleaner before painting.
my strength lies solely in my tenacity
Offline Jwebb
Re: Caliper paint
« Reply #6 on: January 31, 2015, 06:46:02 pm »
Have used Hammerite myself in the past with no trouble, but have always brushed on rather than spraying.
This is the guide I used the 1st time around: http://www.golfgtiforum.co.uk/index.php?topic=77966.0
Offline grey golfster
  • -Given: 79
Re: Caliper paint
« Reply #7 on: January 31, 2015, 07:10:04 pm »
Recently used red Foliac, brush on.
Brembo calipers, off the car. Took ages to pre, sand with fine wet n dry, degrease etc...
Was working in a warm work shop.
Took loads of coats, and didnt cover well. Really time consuming.
A real pia!
Not pleased with the results.
It was expensive too!
NOT recommended.
  • -Receive: 41
Re: Caliper paint
« Reply #8 on: January 31, 2015, 09:20:04 pm »
I should say as well. I originally did mine when I bought the car about 4 years ago now. Nothing had flaked off. They were just looking a bit dull again so I gave them a quick brush and another coat.
Re: Caliper paint
« Reply #9 on: January 31, 2015, 10:07:56 pm »
used hammer rite smooth on mine
Offline BenMiller692
Re: Caliper paint
« Reply #10 on: March 04, 2015, 06:01:19 pm »
I like the black on the hubs mate. Think im going to have to do that on mine. Didnt notice how bad my hubs looked until i put my fresh painted black wheels on haha
