Author Topic: fitting air suspension  (Read 1215 times)
Offline ash_woolston
  • GTI 07'
  • My Ride: VW
« on: January 31, 2015, 08:05:33 pm »
hi all,
has anybody on here got a build thread for fitting air lift v2 slam series
looking into fitting it, from what i understand its not all difficult but is there any fabrications required for these?
is there any chassis notch or anything needed,
if anyone finds anything out please let me know :D
Adam Paxton
Re: fitting air suspension
« Reply #1 on: January 31, 2015, 08:51:37 pm »
It's easy mate if you can fit coilovers and run sub wire neatly it will be a piece of cake  :happy2: iv fitted it to my gti all on my own so so easy the only thing I got someone else to do was my chassis notch so the drivers side went down all the way and wasn't sat on driveshaft
  • GTI 07'
  • My Ride: VW
« Reply #2 on: January 31, 2015, 10:13:30 pm »
sounds alright then, i work at vw specialist but i have never even looked into it let alone fitted it, but i didnt think it would be that much different :D where did you get your notch done? also what do they actually do? just cut the chassis leg shorter?
cheers pal
« Last Edit: January 31, 2015, 10:18:56 pm by ash_woolston »
Adam Paxton
« Reply #3 on: February 01, 2015, 08:45:07 am »
You'll get on just fine then mate as I'm a tech too
