Author Topic: turbo problems 2.0tfsi 2005 flat / no boost  (Read 14092 times)
Offline jaye2992
Re: turbo problems 2.0tfsi 2005 flat / no boost
« Reply #15 on: February 05, 2015, 02:24:41 pm »
Yea there is a heat shield to come off just 2 bolts then you will be able to check. You can get a forge one that I've seen but it's still a turbo off job.... I've been looking at recons or low mileage turbos
Offline jaye2992
« Reply #16 on: February 18, 2015, 09:00:53 pm »
You sort your problem out? Got mine sorted with a turbo change  :sad1:
Offline muff1991
  • -Receive: 69
« Reply #17 on: March 02, 2015, 11:24:48 am »
im sure I read somewhere on the net but don't know for sure, these cars have a knock sensor which when faulty can reduce power etc or if its doing its job its there to save the engine if theres a problem, just an idea... worth looking into it.
Offline cooljimy84
    • Personal
« Reply #18 on: March 02, 2015, 12:34:50 pm »
YES !! O M G YES !!
Finally got this fixed on mine, there was no fault code/check light on generic tools, i did a scan with vagcom and it showed up knock sensor. I then confirmed this with a bluetooth odb11 tool and torque. She was pulling timings as the revs went up, but boost stayed high.
It's a nightmare to get to, i pray it's not the answer to yours....
There is no replacement for displacement....
But a turbo does help....
Offline muff1991
  • -Receive: 69
« Reply #19 on: March 02, 2015, 12:37:29 pm »
Wahoo, I hope it's not to expensive for ya and not to much of a bugger to sort out, fingers crossed once it's replaced it will fix your problem :-)
Offline Rookie
« Reply #20 on: February 16, 2022, 02:06:52 pm »
I had a similar problem on my edition 30. The pipe that goes on to my turbo had a hairline split init. It was very hard to spot until I took it off and forensically examined it!
