Author Topic: BBK Opinion (VWR / B7 RS4)  (Read 8963 times)
Offline bluo
Re: BBK Opinion (VWR / B7 RS4)
« Reply #15 on: February 08, 2015, 07:42:42 pm »
Anyone know what would be involved in making these work on the golf gti?
http://pages.ebay.com/link/?nav=item.view&alt=web&id=251790566757
Front will be easy providing you can get a bracket to suit them. The rears will be more bother... Electric handbrake.
Thought as much... The seller said he'd do a deal for cash so I thought I'd check first.
I've got the cash so I want to make the right purchase once and there seems to be sooooo much choice so not sure what to go for!
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=2b9eb4rdjnj8ep8c2fposes569&/topic,19740.0.html
« Reply #16 on: February 08, 2015, 07:51:04 pm »
http://www.reyland.co.uk/vw-golf-all-models/
Second down. That's what I would get if I were buying again. AP calipers and AP discs.
Offline bluo
« Reply #17 on: February 08, 2015, 08:24:43 pm »
Why 4 pot instead of 6? (Other than price).
Do you know if the red matches the vw red?
Offline Cossie Killer
« Reply #18 on: February 08, 2015, 08:27:50 pm »
What power are you running?!
Offline bluo
« Reply #19 on: February 08, 2015, 08:50:13 pm »
I'm in the process of upgrading hardware and hoping to be around 380bhp hence stating around 400 in opening post.
I'd like to future proof it a little if poss but open to advice.
« Reply #20 on: February 08, 2015, 08:55:16 pm »
Id of said 4 pots would be ample, but if you were going to spend 2.5k on them brakes on ebay, get 6 pot APs.... Maybe a tad overkill but still cheaper.
« Reply #21 on: February 08, 2015, 08:56:23 pm »
Ps give reyland a call for advice, he'll be able to offer loads with regards to track time etc.
Offline bluo
« Reply #22 on: February 08, 2015, 08:57:36 pm »
Would you do anything to the rears?
  • -Receive: 427
« Reply #23 on: February 08, 2015, 08:59:45 pm »
Get Lambo/R8 8 pots with everthing needed re brackets, discs, pads etc for £2.5k.
Yes, add Audi S3 rear Calipers for their bigger pot and their larger discs (which are also  vented and not solid).
« Last Edit: February 08, 2015, 09:02:05 pm by MC71 »
Offline bluo
« Reply #24 on: February 13, 2015, 06:05:39 pm »
I've made my choice... AP Racing CP5555 6 pots... Thanks for allowing me to bounce ideas of you guys!
« Reply #25 on: February 13, 2015, 11:19:58 pm »
Nice....
« Reply #26 on: February 13, 2015, 11:28:21 pm »
They should do the trick!
Piston area is 2961.76mm2 per caliper
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #27 on: February 14, 2015, 01:18:50 am »
It's just BIG though, it's designed for a 32mm wide disc and they struggled getting a wheel over it so machined each half back by 2mm and used a 28mm wide disc.
Problem is thinner disc equals smaller diameter unless you want to spend GT team money
Offline flashp
  • -Receive: 65
« Reply #28 on: February 14, 2015, 08:11:08 am »
I have mine on order with BG Developments, I went for a variation on this with this kit as they have smaller bodied 'skinnier' calipers which help my wheel clearance.
From the AP site you can download a correctly scaled profile template that you cut out, stick to cardboard and can accurately check clearance.
Mine uses the CP5575 caliper. http://www.apracing.com/product_details/road_car_upgrades/factory_big_brake_kits/vw/golf_mk5_r32-front_6_piston_kit_cp5575m1011-2005_on.aspx
It looks like this:
It also uses strap drive discs which gives you a floating disc without rattling bobbins or springs which need to kept clean. Best of both a floating disc and rigid bolted system in one and a 32mm thick disc.
Useful links:
http://www.bgdevelopments.co.uk/
http://blog.stillen.com/2010/01/technology-spotlight-ap-racing-strap-drive-brake-rotors/
Pagid themselves recommended a new RST3 pad compound for the front (BG can supply this with the kit instead of the default AP404's for an extra £45) and an 'S' series pad for the r32 rears I have. The rear setup should be adequate.
Both of these are fine for both road and track day use.
« Last Edit: February 14, 2015, 05:46:03 pm by flashp »
Gone but not forgotten :-)
Offline Orc
  • -Receive: 25
« Reply #29 on: February 14, 2015, 09:06:40 am »
Awesome I'm after some too what's the price on these dude??
