Author Topic: VAGCOM results, help please....  (Read 5159 times)
Offline piston broke
« on: February 06, 2015, 07:52:16 pm »
Borrowed a VAGCOM from a work mate and got these results...
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 FC    HW: 03G 906 018 FC
   Component: R4 2.0l PPD1.2      1879
   Revision: --H42---    Serial number: VWX7Z0G63N67QQ
   Coding: 0000072
   Shop #: WSC 00397 210 63332
   VCID: 6BDFAC594A605D40E4E
1 Fault Found:
000801 - Engine Speed Sensor (G28)
               P0321 - 006 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 256316 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 05:08:44
             Freeze Frame:
                    RPM: 192 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Time: 0.02 s
                    Angle: 0.0 °
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
Readiness: N/A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0023170
   Shop #: WSC 01279 785 00200
   VCID: 73EFB439125085802CE
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
            012 - Electrical Fault in Circuit
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 79F38611303CFFD0662
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
            000 -  -  - Intermittent
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 01000007323027
   Coding: E78B8F2700041500471400001400000000087F075C000100000000000000
   Shop #: WSC 01367 785 00200
   VCID: 71E3BE31684CB790DE2
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 050707 021  0501
   Coding: 00038805
   Shop #: WSC 01367
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     100707 046  0204
   Coding: 00208933
   Shop #: WSC 01367
1 Fault Found:
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 243879 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 12.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1BP606
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D7B5201649403F00AA
No fault code found.
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BD    HW: 1K0 953 549 BD
   Component: J0527           036 0070
   Coding: 0002002
   VCID: 75EB8A211C249BB002A
   Part No: XXXXXXXXXXX
   Component: E0221           002 0010
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K0 920 974 B    HW: 1K0 920 974 B
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G63N67QQ
   Coding: 0007403
   Shop #: WSC 00397 067 57207
   VCID: 2D5B6241B4F49370BAA
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 020707F2001820
   Coding: 7D0F034007000001
   VCID: 2F677849BEF8E160886
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1216
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
   Component: Tuer-SG         006 120B
   Coding: 0000564
   VCID: 387543154BB626D8D9C
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 36694D2D41A2D0A8CB0
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 819002085103087F2D04840570085AC690BC00
   VCID: 830F64F9C2F03500BCE
   Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H07 9001
   Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
   Coding: 0000564
   VCID: 3973461170BC3FD0262
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000003
   VCID: F4ED3725975E02B8B54
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 195 D
   Component: Radio BVX       014 0034
   Coding: 0040400
   VCID: 275790699608B920406
End   ---------------------------------------------------------------------
It was the ABS light in the dash that made me scan it, seams I have a few other problems too.
Any and all advice very welcome, many thanks.
Andy B.
Offline doylebros
Re: VAGCOM results, help please....
« Reply #1 on: February 06, 2015, 07:58:24 pm »
Since it's got the fault G201 the dealers are doing that fault FOC - take it past them and ask if they'll do it!
Offline doylebros
« Reply #3 on: February 06, 2015, 09:16:45 pm »
Got to be worth a punt I guess, thanks mate will phone them Monday AM...
Offline DANBOY66
  • -Given: 41
« Reply #4 on: February 07, 2015, 05:22:37 am »
 1 Fault Found:
check out headlight washer probably is the fuse no 36 in the fusebox on the drivers side in the dash - 3rd row up from bottom, 5th one in from the right - should be a yellow 20amp -
Dan..
« Reply #5 on: February 07, 2015, 06:19:07 pm »
Mmmmm, how queer, I don't have a F36 fuse, don't have a F32 or F33 either...
F32 is electric windows, but so is F23. But I only have a 3 door so no rear electric windows  so no F32?
F33 is electric sunroof, no sunroof so no fuse!
F34 is electric seats, yep that's right.
F35 Alarm system, yes got that one, should be 5 amps, sure mine is 25 amps, will check again...
F36 no fuse???
F37 Heated seats, yes got that one and its 30 amps.
F38 and F39 not used, nothing in mine too.
Going back with torch and my glasses to check again...
« Reply #6 on: February 07, 2015, 07:12:45 pm »
Well I re checked, and yes there was no F36, metal connections there but no fuse.
Got my spares box out and only had a 10 amp fuse (red), should be OK to check if working, but no, it blew on first use.
Took wife to work and went to Halfords, £1.49 for two 20A fuses...
Came home again and installed one, washed the windscreen about 20 times but still no headlamp washers???
Fuse is still good, I guess it must be the relay now, so where is it and what number???
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #7 on: February 07, 2015, 07:27:33 pm »
Behind the little cubby , under the headlight switch. 2nd from the left (no.4) on the relay carrier. No. 53 relay  :happy2:
« Reply #8 on: February 07, 2015, 07:38:25 pm »
Cheers Freddy, tis a bit dark and cold to go looking now but will check tomoz after work.
Thanks again bud.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #9 on: February 08, 2015, 11:26:14 am »
Sorry mate, got my left and right mixed up  :ashamed:
2nd from the right, as per the below PDF  :happy2:
http://www.golfmkv.com/forums/showthread.php?t=6875&highlight=fuse
« Reply #10 on: February 10, 2015, 11:28:03 am »
Right, update time....
Phoned local VW yesterday morning at 9.30, who said they would ring back, but no call as of 9.00 this morning.
Phoned them again at 9.30 today and spoke to a nice chap called Mark who said that if it was a G201 ABS fault it will be done as a good will gesture, RESULT!
Car booked in for 9.00 tomorrow for check up.
Then had a look for the head lamp wash relay, found it, checked it, re installed, now working ok? Dodgy connection?
Cleared all codes, took it for a spin round the block, re scan and now only the ABS fault showing, this car heals itself!
Happy Days!
Andy B
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
« Reply #11 on: February 10, 2015, 06:26:04 pm »
Happy Days!
Andy B
i had that same issue with the abs pump. i had to fork up £155 for a repair kit :sad1:
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
Offline doylebros
« Reply #12 on: February 10, 2015, 06:41:55 pm »
Happy Days!
Andy B
Pleased your looking good for an FOC Abs pump job! :happy2:
« Reply #13 on: February 12, 2015, 12:53:34 am »
The man from Del Monte, he say YES!
Well Mark from Barnstaple VW service dept' has said that VW will cover the repair of the ABS pump, as long as I am willing to cover the cost of two corroded brake pipes, so happy days, car will be done tomorrow!
Happy does not seam a big enough work some how...
« Reply #14 on: February 14, 2015, 01:34:38 pm »
Another update, went to pick the car up today after a slight delay as the parts got delayed???
Went in paid, £166, full diagnostic and two new brake pipes...
Went to drive home, got to edge of road from their car park, put me foot on the brake to stop, and me foot nearly hits the floor!
Now that ain't right, pump the brakes, no not right, reverse back to car park and stop, just!
Go back in to the service desk, nice young man comes out drives it round the car park and confirms "the brakes are a bit spongy" yeah right!
Well the upshot is they still have the car, going to be investigated on Monday and will call me PM.
Not happy now...
