Author Topic: Sat nav and Highline  (Read 842 times)
Offline EddieA
« on: February 06, 2015, 07:52:35 pm »
probably going to be a really simple answer to this.
when i bought the golf it never came with sat nav or the highline display and no multifunction steering wheel.
i have since added all the above (rns 510, highline and multi function) my question is i can't control the music from the buttons other than the volume, it also doesn't display the song or even the satnav details on the highline.
is there a way that i can get this?
Edition 30 TTE420 - number 470 - RTech 418bhp and 391lbft
Offline skard
  • -Receive: 245
Re: Sat nav and Highline
« Reply #1 on: February 06, 2015, 07:55:15 pm »
When it was coded in, was 37-Navigation selected in module 19-Gateway?
Offline EddieA
« Reply #2 on: February 06, 2015, 08:03:52 pm »
in all honesty i couldn't tell you. and i don't have vagcom to check.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #3 on: February 06, 2015, 08:29:35 pm »
Sounds like a coding issue
Offline skard
  • -Receive: 245
« Reply #4 on: February 06, 2015, 08:32:04 pm »
Where are you situated so a VCDS owner can maybe help you?
Pretty sure what I wrote will get you on your way
Offline EddieA
« Reply #5 on: February 06, 2015, 08:41:56 pm »
thanks for that - will have a look if i can find someone local to have a check for me
Offline Cr33D
« Reply #6 on: February 07, 2015, 11:47:58 am »
Hey Eddie I'm in Portsmouth with full vcds, if it is any help to you...
