Author Topic: GTI Turbo  (Read 1590 times)
Offline jaye2992
GTI Turbo
« on: February 07, 2015, 09:54:17 am »
In need of a new turbo for my GTI due to the actuator snapping. Can anyone recommend a decent place that sell recon turbos or new turbos? Thanks
Re: GTI Turbo
« Reply #1 on: February 07, 2015, 10:17:56 am »
If it's just the actuator that's the problem then you can get a forge one and use their green spring if you are not mapped...
Offline jaye2992
Re: GTI Turbo
« Reply #2 on: February 07, 2015, 11:26:31 am »
Yea thanks, i've just been looking into this, rung awesome gti and they can supply and fit for 4 hours labour which isnt too bad! If i were to get it mapped down the line would a different spring be better?
Offline th3_f15t
  • -Receive: 183
Re: GTI Turbo
« Reply #3 on: February 07, 2015, 11:30:08 am »
Re: GTI Turbo
« Reply #4 on: February 07, 2015, 01:23:40 pm »
You should only use the stiffer yellow spring if you also have an uprated hpfp that will be able to supply the extra fuel. iirc forge only advises the yellow spring with stage 2+ maps.
Offline jaye2992
Re: GTI Turbo
« Reply #5 on: February 08, 2015, 01:08:35 pm »
Thats great thanks for your help! Ordered a standard one yesterday. Even if I map it I will only be going stage 1 so should be fine. Fingers crossed it all goes well now....also got a GFB DV+ to go on  :happy2:
Offline greygti
Re: GTI Turbo
« Reply #6 on: February 08, 2015, 10:16:32 pm »
AKS can supply standard actuators for the Ko3 turbo fitted to the gti
Offline jaye2992
Re: GTI Turbo
« Reply #7 on: February 08, 2015, 10:19:42 pm »
Really?? This is very interesting thanks! I will be phoning them tomorrow.
Offline greygti
Re: GTI Turbo
« Reply #8 on: February 08, 2015, 10:29:36 pm »
Yea I've already spoke to Alex about this , he can source them from Borg Warner (the manufacturer )
Offline mvb12
  • -Receive: 64
Re: GTI Turbo
« Reply #9 on: February 09, 2015, 08:53:03 am »
http://www.mk5golfgti.co.uk/forum/index.php/topic,93578.0.html
Very clean turbo and removed by AKS. thing is mint  :happy2:
