Author Topic: Steering wheel gone heavy after multifunction wheel retrofit  (Read 7498 times)
Offline MAH
Re: Steering wheel gone heavy after multifunction wheel retrofit
« Reply #15 on: February 09, 2015, 10:42:49 pm »
Hi mate, yes it was heavy. One morning I reversed out of the drive and the steering had gone to the other end of the scale. It was so light it felt like the wheels were disconnected  :jumping:
On my journey to town the steering got better and better and the lights cleared  :happy2:
Let's hope it's sorted soon, thanks for the reassurance buddy  :happy2:
« Reply #16 on: February 09, 2015, 10:44:27 pm »
Hopefully It won't take as long as mine did. From what I learned 1000 miles to adapt is unheard of  :driver:
Offline MAH
« Reply #17 on: February 09, 2015, 10:46:29 pm »
Did you not try to resolve the issue via VCDS?
Atleast my shoulders and biceps will benefit from this exercise  :jumpmove:
« Reply #18 on: February 09, 2015, 10:52:56 pm »
Yes mate we tried everything with VCDS  :sad1:
Offline MAH
« Reply #19 on: February 09, 2015, 10:57:40 pm »
Ok, il drive it around for a while and see what happens. Il keep you posted after around 1000 miles
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #20 on: February 10, 2015, 07:21:30 am »
When I do cluster or steering wheel  changes this happens as well. there is a town hall near my house with a roundabout.  I go around that a few times and do a few reverses on full lock and It clears it within 5 miles.
Offline MAH
« Reply #21 on: February 10, 2015, 10:08:48 am »
Unfortunately bro, been driving it around and its still the same. I will continue driving it for abit and see how it goes.
P.s gave you a call in the evening yesterday
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #22 on: February 10, 2015, 10:15:02 am »
Ill drop you a text.
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #23 on: February 10, 2015, 10:16:04 am »
Sometimes VCDS want do it guys i.e. 2 days ago i've changed steering module and o matter how lon i drove or how many basic settings i did, its still the same. So I used other tool and its done straight away.
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline MAH
« Reply #24 on: February 10, 2015, 10:30:03 am »
What tool did you use?
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #25 on: February 10, 2015, 10:49:45 am »
Vag can pro
Offline MAH
« Reply #26 on: February 10, 2015, 11:49:33 am »
Vag can pro
And did that sort it out straight away? Do you have the tool? If so, where abouts are you based?
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #27 on: February 10, 2015, 11:50:54 am »
Yes. Sorted straight away. And yes i have this tool. Redditch based
Offline MAH
« Reply #28 on: February 10, 2015, 11:53:42 am »
Would you be passing by London any time soon I.E. possibly got a group meet with Eddie on the 21st in South London
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #29 on: February 10, 2015, 11:55:48 am »
I dont think so as im doing same things as Ed so no point me to going there hehe
