Author Topic: mk6 climate into 2006 mk5 gti  (Read 45831 times)
Offline Stig_gti
Re: mk6 climate into 2006 mk5 gti
« Reply #15 on: February 11, 2015, 05:35:13 pm »
Mine did the exact same before the wires where changed.
Once they where changed about work perfect and never had an issue with the heated seats.
Offline Softishman
« Reply #16 on: February 12, 2015, 05:17:13 am »
If someone dif this to his 2007 Efition 30, can you please write down exactly wich wires that was changed?!
Offline Stig_gti
« Reply #17 on: February 12, 2015, 08:26:23 am »
2007 should not need wires changing should be straight swap plug and play.
Offline Softishman
« Reply #18 on: February 12, 2015, 08:32:56 pm »
Ok... That sounds promising...!!! :pomppomp:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #19 on: February 13, 2015, 08:53:50 pm »
Mine's a MY2009 and it needed the wires changed so that the control panel would keep it's memory of the selected options after removing the key. :confused:
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #20 on: February 14, 2015, 02:44:26 am »
you need to swap one wire, i did on ym 57 ed30
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline Softishman
« Reply #21 on: February 15, 2015, 06:51:43 pm »
Do you have more info about that?! Witch cables? Pictures?
Offline DSG_Steel
« Reply #22 on: February 17, 2015, 11:32:34 am »
I'm looking to fit mk6 climate control panel in my 2006 mk5 golf gti with econ button. What wires would I need to change?
Offline Grande_GTi
  • -Given: 41
« Reply #23 on: February 18, 2015, 09:44:45 pm »
Love this mod but do we know if it will work with a kenwood d521 dab? Sorry to hijack thread
instgram @ricky_grande
check out @lowlife_official
MK5 GTi OEM+
Offline jedi-knight83
  • -Receive: 41
« Reply #24 on: February 28, 2015, 06:21:26 pm »
Just completed this with help from @Eddie-NL  :notworthy: Thank you again for coming to the rescue last minute... would help if i could flipping count properly !!! (I'm my defence the pin numbers on the plugs are tiny and 18 looked like 16 to me  :ashamed:)
You will need the Climate panel (i got mine for £65 from eBay), a new facia (1K0 858 069 N 1QB - £29.46 inc VAT from TPS), Eddie will make you a lovely loom (i made my own but once i'd bought all the bits from TPS it was £10 MORE than Eddie charges for his pre made one!!)
Follow the vortex guide and make sure you correctly identify pin 16 on the wide black plug!!
http://forums.vwvortex.com/showthread.php?4938269-OEM-MKVI-Climatronic-on-a-MKV-on-a-RNS-510-Screen-installed
For reference here are the pin numbers wire colours
Wide Black Plug
16 - Red / Yellow
Brown Plug
7 - Purple / Yellow
8 - Blue / Red
9 - White / Green
10 - Green / Yellow
Black Plug
6 - Green / White
7 - Purple / Green
One question.. it remembers my temp settings but not the heated set settings.. IE if i have it on level 2 and turn the car off.. when I turn it back on the heated seat is off. Is this correct?
Nathan
« Last Edit: February 28, 2015, 06:23:32 pm by jedi-knight83 »
Offline golfman
  • -Given: 17
« Reply #25 on: February 28, 2015, 06:58:01 pm »
There is something in the Adaption that you can do so it remembers what you had it set to before!!!!
scott :happy2:
Vag-com Hex+Can in scotland
I Hate Timewasters...
  • -Receive: 41
« Reply #26 on: February 28, 2015, 07:10:57 pm »
scott :happy2:
Any idea what or how ?
Offline golfman
  • -Given: 17
« Reply #27 on: February 28, 2015, 07:14:18 pm »
scott :happy2:
If you have vag com go into the ac controller and go into the adaption channels and you will see something for retention of the drivers seat heating just set it to always
job done
scott
  • -Receive: 41
« Reply #28 on: February 28, 2015, 09:36:16 pm »
scott :happy2:
job done
scott
Excellent. I do have vcds. I'll do it later.
Offline Softishman
« Reply #29 on: March 01, 2015, 09:09:53 pm »
What cluster do you have? Looks really nice!!!
