Author Topic: mk6 climate into 2006 mk5 gti  (Read 45845 times)
Offline K9
  • VW LifeStyle
Re: mk6 climate into 2006 mk5 gti
« Reply #45 on: November 05, 2015, 04:07:33 pm »
I plugged the Mk6 unit in first to check it and everything seemed to work?! What do all the wire swaps allow to happen?
i guess it depends on the year of your car
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #46 on: November 05, 2015, 04:29:17 pm »
Have you turned off the car and back on again? For late models the pin swap only allows the panel to remember the settings after the car being turned off.
Offline Lyons
  • -Given: 18
« Reply #47 on: November 05, 2015, 04:49:05 pm »
Yes. Temperature remained the same.
Mine is early 07.
What does the pin swap do on early models? Do all pin swaps just cover the memory side of it- 16 to 20 and the other ones? Or are they for separate things?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #48 on: November 05, 2015, 04:59:06 pm »
Mine is early 07.
AFAIK the early models need the flap motors in parallel as well:
Quote
Motors in parallel:
On C Connector (brown): Pin 7 connected to Pin 10 and Pin 8 connected to Pin 9
Offline Lyons
  • -Given: 18
« Reply #49 on: November 05, 2015, 05:09:22 pm »
Right ok, so the pin 16 to 20 is the memory side of it?
I might just install it then and use it for a while to see what happens.
What constitutes as an early model anyway?! Up to when??
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #50 on: November 05, 2015, 05:58:02 pm »
The late version only has 1 flap engine, while the early had 2. I think the early models were made till mid 2006, not sure about this AC feature.
Offline Lyons
  • -Given: 18
« Reply #51 on: November 05, 2015, 09:53:37 pm »
Cheers. I'll get it fitted and see what happens over the next few days.
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #52 on: March 10, 2016, 01:22:56 pm »
Please can someone shed some clarity regarding the secondary wires needed
Also if the air quality sensor is wired as shown?
I have put together a diagram to help explain what I don't understand.
Eddie NL has ignored my question on here.
I also sent a PM asking to buy a wiring loom.
Totally ignored.  I thought we were meant to be helpful on here!
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline Softishman
« Reply #53 on: March 10, 2016, 10:21:20 pm »
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #54 on: March 11, 2016, 08:19:15 am »
Thank you :)
The pictures refer to plug 'A' which pins 16 & 20 have different size connectors.
I'm almost certain I have plug 'A' sorted.
It is plugs 'B' & 'C' that I really want to know which way to go.
Offline SI-R32
  • -Receive: 125
« Reply #55 on: March 11, 2016, 08:44:57 am »
From your picture B,  B,  modified is the correct way
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #56 on: March 11, 2016, 01:37:27 pm »
Thank you Si :)
So this looks to be correct now.
Anyone can feel free to share this, in OK :)
Offline jedi-knight83
  • -Receive: 41
« Reply #57 on: March 12, 2016, 11:10:39 am »
Anyone else getting really bad misting up after doing this mod? I have to have the aircon on all the time now even if its a nice day. Never had to before doing this mod.
Offline downtime
« Reply #58 on: March 15, 2016, 08:45:11 am »
I have the same issue. I don't know why. With MK5 climatronic panel no misting problems but with the new one really bad misting.
Have you checked that the air recirculation flap is not closed? Newer type circulation only has one big flap that moves over the blower to change the air flow. You can also listen to the sound when pressing recirculation to on, if the sound changes then the flap is working ok.
On mine the flap is doing what it's supposed to do, but  still the misting is bad.
Offline Softishman
« Reply #59 on: March 20, 2016, 12:58:15 am »
I think it is what my pictures are for!!! You need to do as i did wirh the wires to override the flap!!
