Author Topic: RCD300 AUX help  (Read 2625 times)
Offline ams_sxi
RCD300 AUX help
« on: February 12, 2015, 11:13:14 am »
I bought the cd changer to jack adaptor for AUX connection, fitted it into the back of the RCD300 but when i press the CD button twice it does not activate the AUX?
Anyone know how to fix this?
In my previous MK5 it worked straight away.
This is the one i have
http://www.ebay.com/...6fa38d2&vxp=mtr
Offline Flyingscotsman
  • -Given: 26
Re: RCD300 AUX help
« Reply #1 on: February 12, 2015, 11:29:41 am »
Is it the "Connect2" adaptor.  If so, in addition to the plug you needs a separate ground connection to the case of the RCD 300. If I remember correctly there is a loose black wire - i used a small self tapping screw to fix it to one of the holes in the metal casing of RCD 300
Offline killsta
Re: RCD300 AUX help
« Reply #2 on: February 12, 2015, 08:26:12 pm »
Your eBay link doesn't work!
