September 21, 2024, 11:59:54 pm
All Things Mk5
Sat Nav and Car Audio
RNS 510 and Highline issue
Topic: RNS 510 and Highline issue (Read 1496 times)
Rob GTI
Won't Shut up.
-Given: 44
-Receive: 11
November 25, 2009, 09:37:08 pm »
Had my RNS for about 6 weeks or so now and noticed today that the compass screen on the MFD was not showing road name as it usually does, then I also noticed the direction on the compass was locked (i.e. not moving as I turned corners) although the arrow next to the clock was showing the correct direction. Going into navigation mode the screen worked as normal. Anyways after switching the car off for half hour or so it all started working fine
Any one had experience of this, the car has not been coded with VAGCOM so maybe this is it??
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
JPC
Just look at my post count
-Given: 93
-Receive: 111
Re: RNS 510 and Highline issue
Reply #1 on:
November 25, 2009, 11:30:53 pm »
You may need to turn off the compass in the car, then the car can read for the compass in the rns. Did you have a factory fitted nav before the rns?
Rob GTI
Won't Shut up.
-Given: 44
-Receive: 11
Reply #2 on:
November 26, 2009, 09:08:27 am »
No I had RCD300 before, how would I turn compass off, I thought the only way the car knew the drirection was throught the GPS antenna.
All Things Mk5
