Author Topic: Horn not working after MFSW swap-another fault appeared!  (Read 2169 times)
Offline andybon
« on: February 14, 2015, 11:21:41 am »
i have just fitted my MFSW and harness put it all back together and tried the horn and it doesn't work. I have connected the new loom exactly as the old standard loom and it doesn't work.
I haven't fitted the steering controller yet as this needs coding in, will this be the problem, or have I damaged something doing the swap?
« Last Edit: March 01, 2015, 01:28:52 pm by andybon »
How hard can it be?
Re: Horn not working after MFSW swap.
« Reply #1 on: February 14, 2015, 11:44:13 am »
sounds like the controller
Offline andybon
« Reply #2 on: February 14, 2015, 04:31:18 pm »
I'll.see if it works when the new one is put on, hopefully it will do
How hard can it be?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: February 14, 2015, 04:36:05 pm »
happenned to me a few years back until I changed and coded the swcm.
how come you didn't fit the control module at the same time?
Offline andybon
« Reply #4 on: February 14, 2015, 08:00:08 pm »
I didn't think I would be able to. I was under the impression I needed to have it coded before fitting, which will only be happening next week. Will I be ok to do this and run around till it gets coded in?
How hard can it be?
Offline andybon
Re: Horn not working after MFSW swap-another fault appeared!
« Reply #5 on: March 01, 2015, 01:30:23 pm »
Steering wheel is in and working along with the horn.
Next question is the star button and the phone button don't work on the wheel, I have a Bluetooth module and a RCD 510 dab radio fitted, just wandering what is needed to get them working?
How hard can it be?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #6 on: March 01, 2015, 02:42:16 pm »
Depends on you bluetooth module i think. My star activates voice control i think
Offline andybon
« Reply #7 on: March 01, 2015, 03:26:34 pm »
I have controller no 5KO 035 730D in, I have a diagram that was sent win the lead is it just a case of connecting the wires as follows and it will work or is yet more coding required?
[/URL]
Will this also make the telephone symbol on the wheel work too?
How hard can it be?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #8 on: March 03, 2015, 09:53:38 pm »
Probably more coding, telling it about the voice control.
The phone button im not sure about
Offline andybon
« Reply #9 on: March 03, 2015, 10:01:37 pm »
I'll see if that can be sorted when I finally get the clocks done, thanks  :happy2:
How hard can it be?
Offline atd_plus
« Reply #10 on: March 18, 2015, 07:05:04 pm »
HY! Could you tell me how you solved the horn? I have the same problem, I fitted a Highline MFSW Module and now the horn isn't working. Thanks!
