Author Topic: Changing Rear Caliper  (Read 2140 times)
Offline Stamanatic
« on: February 14, 2015, 02:16:23 pm »
Hello,
Going to be replacing my rear caliper, what size tube do I need to fit around the bleeder so I can bleed it, also do I need to bleed every caliper on the car if only changing one? I am replacing the rear drivers side caliper. Will I also need to top up the fluid?
Offline omeydz
  • -Receive: 50
Re: Changing Rear Caliper
« Reply #1 on: February 14, 2015, 03:44:09 pm »
Hi mate. Tubing can be about 10mm outer diameter. Only need to bleed the caliper you are changing and will need to top up fluid as you will lose some to filling the new caliper. Hope that helps!  :happy2:
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
Offline Stamanatic
« Reply #2 on: February 14, 2015, 04:24:28 pm »
Cool thanks for the info! :D
Offline Stamanatic
« Reply #3 on: February 16, 2015, 10:33:47 am »
Just noticed there while buying online, some tubes, have an exterior of 10mm but some have 8mm interior and some others have 5mm interior. I suppose the question I have what's the interior mm I'm looking for? Cheers
Offline omeydz
  • -Receive: 50
« Reply #4 on: February 16, 2015, 01:01:02 pm »
Dont know internal diameter, but in fairness the tubes are very flexy so you should be fine
Current Rides
SOLD
2008 Audi A5 3.0TDI
Offline Flyingscotsman
« Reply #5 on: February 16, 2015, 03:34:56 pm »
The tubes are flexible - if you need to you can tighten it round the bleed-nipple using a cable tie
