Author Topic: How to fit hid kit?  (Read 3050 times)
Offline anderson9
How to fit hid kit?
« on: February 14, 2015, 06:54:51 pm »
Has anybody fitted these I can't find out how to connect the bulb to the car ?
Offline screech
Re: How to fit hid kit?
« Reply #1 on: February 14, 2015, 09:05:25 pm »
Find nearest bin, open, insert... Job done.
Sorry.
« Reply #2 on: February 14, 2015, 09:10:45 pm »
hids in normal lights are horrendous and don't don't give proper beam pattern so blind on coming traffic
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #3 on: February 14, 2015, 09:11:31 pm »
Sorry.
x2
Dangerous, illegal and bad for other road users through being dazzled by the chavvy "its blue innit" bulbs
Offline jaffa
  • -Receive: 44
« Reply #4 on: February 14, 2015, 09:55:01 pm »
X2 don't use them unless you have projectors
I'm sick of being blinded by corsas with hid's fitted
Kam88
« Reply #5 on: February 14, 2015, 10:17:11 pm »
By the looks of it great help from everyone above. Hard to explain fitting over forum have a look at YouTube they are dead simple take about 10 mins
Offline boardyuk
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,88307.0.html
« Reply #6 on: February 14, 2015, 10:29:07 pm »
Please don't fit these unless you have projector lights, you'll blind everyone else on the road. I've installed a 5000k HID xenon conversion kit in some Depo projectors recently and it's really simple to do, just follow the instructions provided.
Offline anderson9
« Reply #7 on: February 15, 2015, 12:14:37 pm »
Calm down lads here not going in standard headlights, does the positive and negative need wiring to the battery ?
Offline boardyuk
« Reply #8 on: February 15, 2015, 12:21:02 pm »
The HID kit should come with ballasts which connect to the original wiring and then the bulbs connect to the ballasts. If you have a look at my build thread you can see my Depo lights setup ready for the going in the car.
Offline anderson9
« Reply #9 on: February 15, 2015, 12:45:40 pm »
So they don't need wiring to the battery ?
Kam88
« Reply #10 on: February 15, 2015, 08:03:23 pm »
Only h4 bulbs need battery feed otherwise no you connect everything to ballast and from balast to headlight
Offline anderson9
« Reply #11 on: February 16, 2015, 08:42:18 pm »
I've had to order some bulb adapters for them, as I don't get a connection to the headlight
Kam88
« Reply #12 on: February 17, 2015, 06:03:34 pm »
What bulb is it h7 or h1 ? Where are you based ?
Offline anderson9
« Reply #13 on: February 22, 2015, 09:07:54 pm »
H7 bulb, I'm in Newcastle, I've fitted them now.
