Author Topic: Thermostat  (Read 2768 times)
Offline Carl123
Thermostat
« on: February 16, 2015, 10:16:38 am »
I know my engine has the common thing about the main thermostat needed to be changed but how do I know if it's the main one or the second one my car reached 70 fine on short journeys has to be driven quite a while longer to get to 90 but like most ppl when costing etc it drops down
Offline GTIEagles
Re: Thermostat
« Reply #1 on: February 16, 2015, 11:46:56 am »
I think if the inline thermostat has gone it will eventually reach 90 degrees but very slowly and it should stay there.
But if the main thermostat has gone it may or may not reach 90 degrees and the temparature will definately drop when coasting.
So it sounds like your main thermostat has gone.
« Last Edit: February 16, 2015, 11:50:50 am by cnut »
Offline Carl123
Re: Thermostat
« Reply #2 on: February 16, 2015, 12:23:43 pm »
Well it gets to 90 after a while doesn't drop massively tho I'm sure there was a thread I see on here the other week explaining that you can use the climate controls to work out temperatures etc I don't wanna have to pay out for the main one when it might not be
Offline GTIEagles
Re: Thermostat
« Reply #3 on: February 16, 2015, 02:01:14 pm »
Try the inline first and if that doesn't do it, it's definately your main. The inline shouldn't take too long to do looking at the guides but the main looks to be a right PITA so probably best left to a garage.
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
Re: Thermostat
« Reply #4 on: February 16, 2015, 07:25:48 pm »
Worth trying inline first as its much cheaper. The inline cured my slow warm up, but the temp was still going up and down after it reached 90. I had to get the main one done to cure this but was quite expensive though at three hours labour.
Offline SkyJawa
Re: Thermostat
« Reply #5 on: February 17, 2015, 09:25:20 am »
If it fluctuates off 90 your main is gone, once its there it shouldn't move.
If it also takes ages to get there/warm up then your inline stats (actually referred to as regulators) are shot too.
I've replaced both (at separate times) and it was only doing both that fixed all the issues.
Offline Carl123
Re: Thermostat
« Reply #6 on: February 21, 2015, 07:14:54 am »
How much are people paying for the thermostats to be changed as I heard the main one is abit crap to get too??
Offline SkyJawa
Re: Thermostat
« Reply #7 on: February 21, 2015, 01:39:58 pm »
Got ours done under approved used warranty, but I think it was north of 200 quid mark iirc.  I think its about a 4 hour job!
Offline Carl123
Re: Thermostat
« Reply #8 on: February 21, 2015, 02:09:40 pm »
Wow didn't know thermostats cost so much now days  :confused: oh well if needs must
Offline Dave(tm)
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89462.0.html
Re: Thermostat
« Reply #9 on: February 21, 2015, 05:05:16 pm »
Mine has approved warranty too and the main stat seems to have gone. Best get it booked in eh.
Dave
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
Re: Thermostat
« Reply #10 on: February 21, 2015, 07:01:10 pm »
Just got my main one done recently for £230 with 3 hours labour.
Offline GTi-Andy
Re: Thermostat
« Reply #11 on: February 21, 2015, 07:36:47 pm »
£137 to get mine replaced recently. Took my mechanic around 3 hours, mates rates
So much for keeping it standard!
Offline jedi-knight83
  • -Receive: 41
Re: Thermostat
« Reply #12 on: February 21, 2015, 08:08:09 pm »
£230 for a thermostat!! Jesus.. I think mine is gone / going too but didn't expect this much.
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
Re: Thermostat
« Reply #13 on: February 21, 2015, 10:10:27 pm »
I know, its a shocker! Its the labour that's a killer, the parts only about £30.
  • -Receive: 41
Re: Thermostat
« Reply #14 on: February 21, 2015, 10:56:38 pm »
what need to come apart to get to it?
