Author Topic: Front strut bolts  (Read 3181 times)
Offline ruhaleali
Front strut bolts
« on: February 18, 2015, 08:07:33 pm »
Hi guys,
I had purchased coilovers for my mk5. Having fitted three, the front right was the last left. However, the 3 bolts from uptop that hold the strut up haveheavily rusted from underneath. The garage has struggled to get these out. What is a possible solution ? As If i can remove then how much are these screws, and my new suspension will be complete. The garage spent 2 hours and wasnt able (vw specialist).
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Front strut bolts
« Reply #1 on: February 18, 2015, 08:30:45 pm »
Drill it off from the top. If you drill off the head you can remove the strut  :happy2:
I had to do this with one of mine
Offline ruhaleali
« Reply #2 on: February 18, 2015, 10:03:22 pm »
Thank you for the info ! Real pain in the ass! How did you get the plastic off that is under the windscreen wipers ? Many thanks
Offline Cooper
« Reply #3 on: February 19, 2015, 10:39:02 am »
Remove the front wipers and it unclips from below the windscreen.
If your VW specialist doesn't know how to do that I'd be a little worried about them fitting suspension!  :scared:
Also if you can't get the three bolts out from the top mount you may need a new top mount as the captive nut on the bottom may have snapped off, had this happen on a few car's I've changed suspension on.
« Last Edit: February 19, 2015, 10:40:56 am by Cooper »
C63
SQ5
Offline ruhaleali
« Reply #4 on: February 20, 2015, 01:11:55 am »
All sorted ! Dipped em heavy inWD40. He then changed everything over and its looking mint!
