Author Topic: Wheel guys answer this.  (Read 2489 times)
Offline K9
  • VW LifeStyle
« on: February 21, 2015, 11:16:43 am »
hey. i bought a new of new summer rims and the specs are
Front 19" 8.5" ET45
Front tire 215/35/19
Rear: 19" 8.5" ET45
Tire 215/35/19
test fitted the rims at front in a local tire garage and the car was in air when tested the front and it poked 1cm at the front. will it go in when lowering on kw v1 and some front camber?
the susspension was all the way down becouse the whole car was in air when tested. pretty hard to explaine here  :ashamed:
dansmith180
Re: Wheel guys answer this.
« Reply #1 on: February 21, 2015, 01:12:35 pm »
I'm running 19x8 et45 fronts with 225/35/19, also on the KW V1's I did have some rubbing at the front so your arches will probably need rolling (depends how low you're going)
Rears will be fine.
Offline ruhaleali
« Reply #2 on: February 21, 2015, 01:48:00 pm »
Front 19" 8.5" ET45
Rear: 19" 8.5" ET45
Tire 215/35/19
I am running 235/35/19 I was out 1 cm after lowering it came to around 0.7 you wont get the tuck you are expecting unless you flare the arches. The ride is good until a hard bump slight rub. Mine are ET35 8.5j so very similar. Hope this helps.
Offline K9
  • VW LifeStyle
« Reply #3 on: February 21, 2015, 01:49:51 pm »
Rears will be fine.
How much camber did you have at front?
Skickat från min SM-G900F via Tapatalk
dansmith180
« Reply #4 on: February 21, 2015, 01:52:28 pm »
Rears will be fine.
Nothing more than the usual amount, I don't know exactly I don't have the tracking sheet to hand.
Offline jaffa
  • -Receive: 44
« Reply #5 on: February 21, 2015, 02:19:43 pm »
you won't need any camber up front
if you do the arch screw mod it may occasionally touch depending on road surface and how you turn in
if you slightly roll your arches you not rub at all
what wheels have you got on now? specs?
Offline K9
  • VW LifeStyle
« Reply #6 on: February 21, 2015, 04:36:56 pm »
now winter rims, but summer oem monza 1 17". how is the screw mod?
Offline jaffa
  • -Receive: 44
« Reply #7 on: February 21, 2015, 05:01:25 pm »
your new wheels will poke 18.7mm more than your monza's
screw mod is removing a screw in the front wheel arch that holds the arch liner in place
you basically remove the screw and put the plastic arch liner tab behind the metal tab from the wing and bend it back into place to hold it there.
this gives you more clearance when changing wheels or lowering as the screw is the first thing the tyre rubs on  :happy2:
have a look on here to give you a better idea
http://www.golfmkv.com/forums/showthread.php?t=10909&highlight=fender
Offline K9
  • VW LifeStyle
« Reply #8 on: February 21, 2015, 05:07:49 pm »
the monzas are sitting really far in imo. guess i will use some spacers at the rear to get the stance correct and little negative camber at front and rear  :happy2:
Offline jaffa
  • -Receive: 44
« Reply #9 on: February 21, 2015, 05:39:29 pm »
Rear should sit pretty flush
You won't get any front camber unless you get adjustable top mounts or super pro ball joints
Offline dom069
« Reply #10 on: February 21, 2015, 06:40:42 pm »
The wheels will naturally tuck in the more you lower it, if you've only got 1cm of poke with no load on the suspension then I'd be pretty sure that when you've got the coilovers on and the car is on the ground then you'll be fine.
BC Racing Coilovers : R32 Rear Bumper : Milltek Cat Back : R32 Rear Lights : S3 Brakes : Colour Coded Side Skirts : US Grill : 18" BBS CH : De-Wipered : Bluefin Remap : Pipercross Filter : S3 Short Shifter : Powerflex Wishbone Bushes : MK6 Steering Wheel : RCD510
Offline K9
  • VW LifeStyle
« Reply #11 on: February 21, 2015, 09:13:12 pm »
hope so. thinking of doing the screw mod in arch when chamging coilovers :)
