Author Topic: Mk4 R32 gone, Hello more fuel friendly Mk5 GTI  (Read 4873 times)
Offline Nino
Re: Mk4 R32 gone, Hello more fuel friendly Mk5 GTI
« Reply #15 on: February 28, 2015, 10:46:32 pm »
The one on the right is to tell you one of the tyres is or has lost pressure
So i just press it and if they are low it will tell me?
Thanks, makes perfect sense now :)
No.  what you need to do is go to a garage and set all your tyre pressures correctly (or check they are ok etc).  When you know they are ALL correct, get in the car with the ignition on and hold the button down until you hear a beep/chime.  Any dash light for the tyre pressure will go out, and the car can now read any loss from 'your set pressures'.
