Author Topic: Midline to highline clocks  (Read 1313 times)
Offline MJGib
  • -Given: 22
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,85702
« on: February 24, 2015, 12:00:55 am »
Want to convert my midline clocks to highline clocks
My clocks end in 964
Would 974 r32 clocks be plug, program & play?
What numbers the easiest to program?
MK5 Golf GTI: K04 converted stage 2+ (I don't own this car no more)
Insta - gibs94_
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Midline to highline clocks
« Reply #1 on: February 24, 2015, 01:46:36 am »
kalu or eddie can read 964 clocks.  you can easily read and program older clocks ending in 0, 1 or 2 using vag commander.
Offline MJGib
  • -Given: 22
« Reply #2 on: February 24, 2015, 08:40:31 am »
So I need 0, 1 or 2?
Insta - gibs94_
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: February 24, 2015, 09:12:06 am »
you can buy it, but u still need to get the SKC from your current clocks. The clone version of Vag commander wont do that, hence you will need to get in touch with Kalu or Eddie
Offline MJGib
  • -Given: 22
« Reply #4 on: February 24, 2015, 09:26:26 am »
Ah I see but if i get 0, 1 or 2 I don't have to get the SKC from my current clocks?
Insta - gibs94_
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: February 24, 2015, 09:47:36 am »
you still need it. Without your current SKC you cant code new clocks to your car. Only way to get your current SKC is from the above 2 members. and to program it back to a 973 or 974 cluster, you still need to contact them.
Offline MJGib
  • -Given: 22
« Reply #6 on: February 24, 2015, 09:49:28 am »
Ok thanks mate  :drinking:
Insta - gibs94_
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #7 on: February 24, 2015, 05:42:09 pm »
Pm sent
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
