Author Topic: Brake discs & pads CHOICES  (Read 1940 times)
Offline AliGTI
  • -Given: 28
« on: February 24, 2015, 06:35:10 pm »
Evening fellow MK5ers
I'm looking to replace my discs and pads but I'm not sure what to replace with or where from. There seems to be a whole range from filthy cheap to 'are you sitting comfortably' expensive. What's the best for OEM performance or slightly better???
Offline mk5-beast-91
  • instagram: subarukid24
Re: Brake discs & pads CHOICES
« Reply #1 on: February 24, 2015, 06:56:34 pm »
i replaced mine with brembo discs and pads. standard size as oem and oem calipers. when  need to replace them again ill go for the s3 setup.
my strength lies solely in my tenacity
Offline AliGTI
  • -Given: 28
« Reply #2 on: February 24, 2015, 06:59:23 pm »
So what kind of cash, if you don't mind me asking is in the Brembo setup you have, and what changes for the S3 setup?
« Reply #3 on: February 24, 2015, 07:02:42 pm »
cant remember price of top of my head but ill have a look and let you know. i think around 300 ish for front and back but could be wrong.
s3 setup is bigger calipers, bigger disc and pads.
Offline AliGTI
  • -Given: 28
« Reply #4 on: February 24, 2015, 07:05:02 pm »
Just had a peek on Ebay. Found a couple of listings for Brembo pads and discs for £100ish for the front. Steer clear???
« Reply #5 on: February 24, 2015, 07:07:38 pm »
is that just discs or with pads?
ill check now wat i payed.
might want to also look at braided lines. made a nice improvement to braking over oem hoses.
« Reply #6 on: February 24, 2015, 07:21:29 pm »
cant find the invoice but i remember it was about 300 ish
the ones on ebay seem genuine enough, look like the same ones ive got.
Offline SpecialistPhil
« Reply #7 on: February 24, 2015, 07:29:25 pm »
Changed mine to brembo front and back pads and discs. Got mine off ebay from quality car parts, £95ish the front and £70ish the rears included discount when you bought the full set. Very helpful with no problems, great stopping power. Genuine VW are a fortune, think I was quoted £75 +vat per disc and the same again for the fronts alone! My local specialist vasstech said they would always reccomend using genuine parts for a quality fit but said the brembo should be just as good. I thought so, don't brembo specialise in brakes???
Offline AliGTI
  • -Given: 28
« Reply #8 on: February 24, 2015, 07:30:33 pm »
Cool! Thanks for your advice. Did the brembo stuff improve the braking over the OEM fit? Not sure I'm up for brake lines, not sure how to bleed them after. Nice engine bay!!!
Offline AliGTI
  • -Given: 28
« Reply #9 on: February 24, 2015, 07:32:37 pm »
Sounds ideal to me! I'm off to ebay, I may be some time :)
Offline Spankiee
  • -Receive: 20
« Reply #10 on: February 24, 2015, 07:32:46 pm »
Mtec are highly thought of on ebay for disks
candy white edition 30
« Reply #11 on: February 24, 2015, 07:34:46 pm »
i noticed i slight difference but not huge. feel more comfident with them over oem tho. the brakes lines firmed the pedal up and gave abit more response to. definatly feels better over oem.
thanks mate  :happy2:0
@SpecialistPhil yer ive herd they know there stuff when it comes to brakes  :signLOL:
Offline sgour
« Reply #12 on: February 24, 2015, 07:35:16 pm »
Slightly related - the brembo pads have no wear indicator? Does this just get coded out on vagcom or is there some other way of getting rid of the warning light?
« Reply #13 on: February 24, 2015, 07:39:21 pm »
i had no issues with it. my pads came with the wear indicator which plugged into the normal socket.
« Reply #14 on: February 24, 2015, 08:47:17 pm »
Mine had wear indicators as well!
