Author Topic: coilover/ tyre rubbing help!  (Read 1182 times)
Offline sherwood989
« on: February 25, 2015, 09:40:47 pm »
hi everyone, just got some Apex coil overs fitting and have been playing around with the ride height. So I found the right height for them not to rub on the lining but now they are rubbing on the tyres!! its only on the left hand side and when the wheels are straight or turning right, turning left is not a problem and can't hear anything.
SO what could i do to stop it rubbing? spacers? will this make the tyre stick out to far and cause rubbing on the arches again?
Any help would be great!
dansmith180
Re: coilover/ tyre rubbing help!
« Reply #1 on: February 25, 2015, 10:12:33 pm »
Sounds like you need spacers and then roll the arches so they fit. Is it the fronts your having trouble with? What offset and width are the wheels?
Offline Llew
  • -Given: 45
« Reply #2 on: February 26, 2015, 06:19:31 am »
Have you had your wheel realignment done as this can prevent rubbing also
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
Offline dom069
« Reply #3 on: February 26, 2015, 05:35:41 pm »
What width and offset wheels are you running?
BC Racing Coilovers : R32 Rear Bumper : Milltek Cat Back : R32 Rear Lights : S3 Brakes : Colour Coded Side Skirts : US Grill : 18" BBS CH : De-Wipered : Bluefin Remap : Pipercross Filter : S3 Short Shifter : Powerflex Wishbone Bushes : MK6 Steering Wheel : RCD510
Offline sherwood989
« Reply #4 on: February 26, 2015, 08:13:49 pm »
thanks for the advice everyone but i worked out what it was... a leaking shock.
taught me a lesson not to buy second hand coil overs. any idea on places that will sell 1 unit or is it best to contact the maker?
Offline Llew
  • -Given: 45
Offline sherwood989
« Reply #6 on: February 27, 2015, 05:08:48 pm »
is there a way of using the coil over (the bit that twists to change the height) on these? can you just change it shock over or are they attached? thanks
