Author Topic: Leak in intake system fault HELP  (Read 4944 times)
Offline Ma22789
« on: February 28, 2015, 07:23:06 am »
Right so I have this code p2279 leak in air intake system lower limit reached I need this code gone so rtec niki can go ahead with mapping my car I have changed the inlet manifold the pcv all the gaskets and pipes Iv had 2 smoke tests done and I have removed my runner flap delete and put the flaps back in with the motor and the code still manages to come back im on the verge of selling up  :sad1: when I done the smoke test its loosing pressure so I'm guessing there must be a leak somewhere rite ?
  gti ed30 2007 stage 2+ ths loba bcs itg
Offline DomBacon
Re: Leak in intake system fault HELP
« Reply #1 on: February 28, 2015, 08:48:05 am »
I had this problem for ages it drove me nuts!!!!
My smoke pressure tests didn't loose any pressure though!
You checked your dv?
Checked all the pipes are firmly in properly?
Mine was caused by my gasket on my downpipe from the turbo!
Offline Ma22789
« Reply #2 on: February 28, 2015, 10:03:23 am »
I have had the manifold of 4 times and dv is good and was yours the metal gasket between the turbo and exhaust ? I never would have thought that would throw up that code ?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #3 on: February 28, 2015, 10:07:57 am »
Did you replace the gasket on the inlet manifold?
Only others I could think of are:
-air intake pipe to turbo
- DV split
-intercooler pipes
- PCV where it connects to inlet mani (or boost gauge tap if you have one)
Offline DomBacon
« Reply #4 on: February 28, 2015, 11:02:06 am »
Yeah that's the one!
Replaced it and it never came back! It fell apart in my hands :/
Strange I know, only noticed it was gone when trying to look for the leak!
Offline Ma22789
« Reply #5 on: February 28, 2015, 12:09:15 pm »
- DV split
-intercooler pipes
Changed all gaskets and dv is good it lost on what to do now  :sad1:
Offline Ma22789
« Reply #6 on: February 28, 2015, 12:10:28 pm »
I will give it a go knowing my luck it ain't that but worth a try lol
Offline Solo9t9
  • Newbie
« Reply #7 on: October 29, 2023, 09:18:13 pm »
Did it help?
