Author Topic: Car accelerates by itself ?  (Read 1693 times)
Jake56672
« on: February 28, 2015, 03:01:47 pm »
Hi all I'm new here and wondered if anyone could help me. I have a 2008  golf gti 2.0t fsi with 62,000 on the clock, my problem is the car seems to accelerate by itself when idil, it reaches 1500 rpm then drops, some times  reaches to 2000 rpm, the power still seems to be there aswell, I have checked the pcv valve by taking of the oil cap, the car started to splutter so I assume everything's fine there, just hoping anyone can help ???? Thanks
Offline AndyBrown
Re: Car accelerates by itself ?
« Reply #1 on: February 28, 2015, 03:07:33 pm »
I've had the same thing and it was the PCV.
Jake56672
« Reply #2 on: February 28, 2015, 03:12:18 pm »
Okay thanks a lot for your help! I will be getting it sorted right away
Offline Jonneh
« Reply #3 on: February 28, 2015, 06:30:48 pm »
I had the same issue and as said it was indeed the PCV. VW also cleaned the throttle body too as they claimed it could also have been that. Either way it worked and stopped the problem!
Passat R36 - Corrado VR6 - Mk2 Golf GTI 8v
