Author Topic: Idle RPM?  (Read 783 times)
Offline Phil_H
Idle RPM?
« on: March 02, 2015, 08:33:35 pm »
Hi,
 I've done a quick search but couldn't find anything...
Whats the correct idle speed meant to be (once warmed up)? And what is everyone getting?
I only ask as mine was a bit lumpy, so changed the PCV and it's better, but still seems a bit crap when warm, mine hunts between 650-700 ish rpm.
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
Re: Idle RPM?
« Reply #1 on: March 02, 2015, 08:48:52 pm »
Mine hunts the same as yours. Did the pcv delete and it was worse. So I just put the pcv back on which it does stop it...slightly still there tho. Been told there must be a air leak somewhere. Yet to find out tho.
Offline Phil_H
Re: Idle RPM?
« Reply #2 on: March 02, 2015, 09:17:14 pm »
Hmmmm..
I may have to do a little digging then!
Offline GTiBlues
  • Mr Blues
    • Bookface
Re: Idle RPM?
« Reply #3 on: March 02, 2015, 09:43:19 pm »
I haven't had the car up on the ramps to have a ganders. Will have a look on Thursday when I get round to fitting my RevG. Will be looking at the newly revised PCV too. Will let you know
