Author Topic: Oil light  (Read 2812 times)
Offline Markweir12
Oil light
« on: March 05, 2015, 08:52:54 am »
Hi,
Yellow oil light came on this morning for me. Always checked level etc but when I finally got to pull over, the cap was full of gunk and so was the dipstick?
The car is my daily and gets driven to and from work and I give it a fair blip too.
Whats broken?
Offline AndyBrown
Re: Oil light
« Reply #1 on: March 05, 2015, 09:19:05 am »
People have had this due to the cold weather but it's mainly people who do short journeys.
How's your coolant level?
Offline Markweir12
Re: Oil light
« Reply #2 on: March 05, 2015, 09:53:29 am »
Coolant level is fine.
I do short journeys to work and back everyday and to the gym.
How do I get the light to go off then?
Offline AndyBrown
Re: Oil light
« Reply #3 on: March 05, 2015, 10:00:12 am »
The gunk will probably be caused by the short journeys it's condensation.
Take the car out for a good drive it might sort itself out.
I would hang about to see if anyone else can shed some light, I'm not an expert that info is from stuff I've read on other threads on here  :happy2:
Probably worth getting it scanned to see if there is any faults there, where are you based?
Have a look on this link and see if there's someone near to you.
http://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html
Offline cooljimy84
    • Personal
Re: Oil light
« Reply #4 on: March 05, 2015, 12:24:52 pm »
I believe the oil light is oil pressure, so if the oil level is ok, it might be not getting up to pressure correctly.
If that's the case i would say don't drive it, low oil pressure is as bad as having low oil, as it needs the pressure to correctly move around the engine.
I take it u've had a look around the engine for leakingness.
There is no replacement for displacement....
But a turbo does help....
Offline Markweir12
Re: Oil light
« Reply #5 on: March 05, 2015, 12:27:46 pm »
Car was on ramp yesterday getting the turbo studs replaced to the downpipe.
Work are gonna do another oil chance and run the diagnostics on it to check the issue
Offline cooljimy84
    • Personal
Re: Oil light
« Reply #6 on: March 05, 2015, 12:37:13 pm »
Kool, well fingers crossed it's some thing simple, like a cable plug left off.
Offline Danbear79
Re: Oil light
« Reply #7 on: March 05, 2015, 04:32:54 pm »
If it was oil pressure it would have a red light and not amber. (Amber is level) My golf showed an amber light once so i opened and closed the bonnet and it's never came on since...
Offline Matthewsimone
  • -Receive: 39
Re: Oil light
« Reply #8 on: March 05, 2015, 04:39:19 pm »
Pick up pipe blocked/clogged in sump
Offline doylebros
  • -Receive: 310
Re: Oil light
« Reply #9 on: March 05, 2015, 05:31:40 pm »
Offline Markweir12
Re: Oil light
« Reply #10 on: March 05, 2015, 05:33:49 pm »
Oil was slightly topped up in garage today - light has gone off.
Gonna take it for a rip tonight and hope the gunk clears itself :)
Will I need to replace the pick up or just clean it.
Offline doylebros
  • -Receive: 310
Re: Oil light
« Reply #11 on: March 05, 2015, 05:44:29 pm »
I wouldn't be doing any ripping until you've cleaned the pickup pipe.
Depending how dirty the pipe is it's quicker just to replace it!
Offline Markweir12
Re: Oil light
« Reply #12 on: March 05, 2015, 06:48:28 pm »
Well he said it was the level light and not the pressure light?
Offline doylebros
  • -Receive: 310
Re: Oil light
« Reply #13 on: March 05, 2015, 06:53:00 pm »
It's a common problem just google it - plenty people have been lucky and undertaken the repair just in time which if ignored is an expensive repair!
Offline Markweir12
Re: Oil light
« Reply #14 on: March 05, 2015, 06:57:43 pm »
Right fair shout.
Will get onto it asap then! Not had the car lomg either!
