Author Topic: Valve Cover Leaking Oil  (Read 13626 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=fdqbh3tkb2f601ki8sal61jj42&/topic,90967.msg917089.html#msg917089
Re: Valve Cover Leaking Oil
« Reply #15 on: May 09, 2015, 04:19:35 pm »
I used a mirror to check the gasket where the leak is. It seems to be sitting nicely.
Could a faulty PCV cause a leak??
05 | Tornado Red | DSG
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #16 on: May 10, 2015, 01:23:30 pm »
Going to get a new PCV on monday. Although i seem to have the correct boost and a rough idle when i pull out the dipstick.
If this doesn't work maybe a new valve cover??
@vRSAlex any thoughts on this??
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #17 on: May 11, 2015, 09:32:18 am »
Just replaced the PCV the old one does not seem to be faulty.
The new one is version R do i need to replace the rear breather tube?
« Last Edit: May 11, 2015, 09:48:16 am by dazza »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #18 on: May 11, 2015, 12:43:10 pm »
By the looks of it i wasted my money on the PCV. Gasket is still leaking.
Before splashing out on a new valve cover going to try and replace the rear breather. As this vents pressure from the crank case??
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
« Reply #19 on: May 11, 2015, 12:57:55 pm »
the rear breather is for both crank and cam cover ventilation 'off idle'
intake pipe via pcv is breather for both 'on idle'
there is no pressure in the rear pipe whatso ever unless (sure you mentioned having the earlier pipe) you hae the check valve pipe and it's faulty - in which case remove the check valve  :smiley:
Touran TFSI Quattro | stage 2+ BHZ | UK's first
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #20 on: May 11, 2015, 01:07:11 pm »
So the earlier pipe will not have a check valve? The PCV i replaced was version L.
So rather than buy a new pipe i should remove the check valve in the rear breather if it has one?
Would this account for the leak?
Offline olethalb
  • -Receive: 31
« Reply #21 on: May 11, 2015, 01:13:31 pm »
only way it would leak is if the rear pipe check valve failed and it's creating pressure off idle, i'd expect exhaust gas to smell a little oilier than usual too.
it's worth a check but sounds more gasket / mating surface related. was it an OEM gasket? and you fitted bolts through gasket before cover installation?
Offline olethalb
  • -Receive: 31
« Reply #22 on: May 11, 2015, 01:19:05 pm »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #23 on: May 11, 2015, 01:25:40 pm »
Yes it was an OEM gasket.
I did not fit the bolts through the gasket before cover installation. I did the first time and it failed.
Offline olethalb
  • -Receive: 31
« Reply #24 on: May 11, 2015, 02:59:53 pm »
9 times out of 10 you can bolt the bolts in after but you risk nicking the gasket, the bolts are designed so the gasket holds them in place when removed, i always push the bolts through the cover / gasket first before fitting.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #25 on: May 11, 2015, 03:16:26 pm »
I've removed the valve cover again. See pick below.
If the rear check valve is in the very end of the pipe i don't have one.
Don't know what to do now.
Offline olethalb
  • -Receive: 31
« Reply #26 on: May 11, 2015, 03:22:04 pm »
check gasket around bolt holes make sure you haven't nicked it anywhere (unlikely you have but worth a check)
stick your finger down rear pipe if it goes all the way you in you have no check valve
check mating surfaces are clean and smooth
also inspect cam cover for damage etc unlikely as that is
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #27 on: May 11, 2015, 08:34:34 pm »
I had another go. Its a bit better still leaking from the back on the right this time.
Debating getting a new valve cover or replacing all of the old bolts??
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #28 on: May 12, 2015, 11:56:52 am »
Went to the stealers today they had a handful of bolts.
So the back and middle row of bolts have all been replaced with new bolts.
There is still a small leak from the very back right. Going to leave it a few days maybe it will stop.
Should i also replace the front row of bolts?
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #29 on: February 19, 2016, 07:11:38 pm »
Did your leak ever completely stop @dazza
