Author Topic: Revs hunting at idle / whistling noise?  (Read 1922 times)
Offline barlimow
« on: March 08, 2015, 02:00:26 pm »
2007 mk5 GTI (85k miles): revs have started to "hunt" at idle. Will go from about 800rpm to 1500rpm, and all inbetween. I also hear a slight whistling noise as well.
The hunting I think is the PCV valve (but that's just from my very limited knowledge of such things!), but not really sure about the whistling - could it be a slight slit in a pipe, or related to the PCV?
The car is already booked in for a service on the 16th March - is anything likely to "fail" before then and leave me stranded, or as long as I take it easy can I probably limp through another week?
Any advice appreciated. Thanks.
Offline AndyBrown
Re: Revs hunting at idle / whistling noise?
« Reply #1 on: March 08, 2015, 03:19:40 pm »
Check the DV for the whistling, that might split.
Saintsteve
« Reply #2 on: March 08, 2015, 03:36:58 pm »
Sounds like the PCV valve has actually blown as it has a small hole in the casing, in which if the diaphragm inside goes, your hear it hiss especially as you shut the engine down on the key . :wink:
Offline PhilNUK
  • -Given: 32
« Reply #3 on: March 17, 2015, 10:14:18 am »
I had the hunting at idle issue about 6 months ago....
I replaced both the PCV and the DV and it fixed it... Worth doing both I think just for reassurance and they aren't expensive parts..
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
« Reply #4 on: March 17, 2015, 10:23:26 am »
I've still got my hunting at idle. Only hunts when you go into neutral at traffic lights or when ever you come to a stop. I've replaced PCV and DV in the last month.
When I opened my door after unlocking. I heard the fuel prime but this time it was hunting to prime. Never done that before, it's always been the usual hum for a second or so. My guess now is my fuel pump at the fuel tank end that's giving up. That's next on my list.
Saintsteve
« Reply #5 on: March 17, 2015, 06:19:35 pm »
Have you checked your fuel pump cam follower? Sounds like that's Knackered if your saying that.
Offline GTiBlues
  • Mr Blues
    • Bookface
« Reply #6 on: March 17, 2015, 08:34:42 pm »
That was just replaced 2 weeks ago. Still no difference.
Saintsteve
« Reply #7 on: March 18, 2015, 04:38:05 pm »
Find someone with VCDS and get them to check your fuel pressure, may be a low pressure pump issue in the fuel tank..
Offline GTiBlues
  • Mr Blues
    • Bookface
« Reply #8 on: March 18, 2015, 06:28:57 pm »
I've got vcds. I know it's my pump at the rear, just need to know which Walbro one to get. I did make a topic but no one said anything yet  :P
