Author Topic: Ticking/tapping sound from drivers footwell (edition 30)  (Read 4773 times)
Offline PhilNUK
  • -Given: 32
« on: March 10, 2015, 02:11:24 am »
Hi guys...  I have been  getting a tapping/ticking sound which lasts about 5 seconds then stops then happens again but there doesn't seem to be a pattern...  It happens under the wheel toward the footwell. Its like water torture as I just listen out for it now...
Anyone had similar...? I am sure I have heard the same coming from the passenger footwell too
Saintsteve
Re: Ticking/tapping sound from drivers footwell (edition 30)
« Reply #1 on: March 10, 2015, 07:00:54 am »
Turn off your aircon. Oh it's normal  :happy2:
I like to call mine our "little mouse with his Castanets"  :laugh:
« Last Edit: March 10, 2015, 07:03:32 am by Saintsteve »
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #2 on: March 10, 2015, 07:28:54 am »
Are you sure it's not the fuel pipe rattling round underneath the car? Common issue
Offline AndyBrown
« Reply #3 on: March 10, 2015, 08:04:37 am »
I get a clicking sometimes, got a fault code which relates to the ignition switch.
When I've googled it a few other people have the same code with clicking.
Offline skard
  • -Receive: 245
« Reply #4 on: March 10, 2015, 08:17:52 am »
It is probably a heating flap motor, every single mk5 based car I have had does it
Offline PhilNUK
  • -Given: 32
« Reply #5 on: March 10, 2015, 08:35:09 am »
Oooof so could be one of a few things...  Is there a proven fix for the fuel line rattle?
It does sound like it's around the knee area to be honest and quite clear..
Saintsteve
« Reply #6 on: March 10, 2015, 09:21:50 am »
Lift the bonnet, look to your left had side and you will see the two plastic fuel pipes coming out of the bulkhead, just give them a small tug and that'll stop the rattle if it's the fuel line rattle that your experiencing under the floor pan  :wink:
« Reply #7 on: March 10, 2015, 04:40:10 pm »
Definitely fuel line rattle.
The cure is to jack it up, drop the plastic floor pan liner, pack the fuel lines with some kind of foam.  I used the grey pipe lagging foam from B&Q.  Shoved a load of that in the cavity around the lines and has been silent ever since.
Just need to sort the hissing (leaking) brake servo next.
Saintsteve
« Reply #8 on: March 10, 2015, 05:16:10 pm »
You don't need to go to that extent, just either tug or push the fuel line in the rubber grommets under the bonnet and the rattle will stop.
« Reply #9 on: April 02, 2015, 03:49:19 pm »
Cool if that works, but it didn't for me. The noise came back after a while.  If you do as I describe, you can see how loose the fuel lines are inside the box section, so it's just a matter of time before they move back into a position where they can tap on the box section again.
Offline Neil 54
« Reply #10 on: April 02, 2015, 07:57:32 pm »
yes grey pipe lagging worked for me to i did fiddle with fuel pipes under bonnet but the noise always came back since pipe lagging no noise :smiley:
Offline Blackgtiman
« Reply #11 on: April 04, 2015, 10:33:28 pm »
yep, prob a hvac motor. they are driving me nuts! let the car down a bit tbh. nothing to worry bout, just annoying. turn up the stereo.
Offline JimGTI
« Reply #12 on: April 05, 2015, 01:02:01 pm »
this has bugged me on mine for months. I thought it was the ipod hard drive in the glove box at first but it is a tap tap tap, in bursts then will stop.
