Author Topic: BSH Engine Mounts Review Update 2/12/09 page 3  (Read 55926 times)
Re: BSH Engine Mounts Review Update 2/12/09 page 3
« Reply #45 on: December 02, 2009, 04:35:33 pm »
I'm actually hoping for a little more noise from my VF mounts.
The BSH ones do look quite similar to the VF ones, but I think the VF ones are a slightly softer grade of polyeurethane.
Mine should be going on tomorrow, so I'll let you know what mine sound like Dave :happy2:
Offline QD MBE
  • -Receive: 102
« Reply #46 on: December 02, 2009, 05:04:21 pm »
cheers mate.  What else are you having done?
« Reply #47 on: December 02, 2009, 05:22:27 pm »
The Quaife ATB LSD is going on at the same time :happy2:
Also the decat (if the flanges arrive!!)
Then going to see if the updated GIAC DSG software is any good.....if not I'm off to Doncaster to get the REVO DSG stage 2 fitted.
Finally, if all goes well I'll be off to have the car dyno'd again :jumpmove:
That's about it for this week :innocent:
Offline QD MBE
  • -Receive: 102
« Reply #48 on: December 02, 2009, 05:34:55 pm »
Sounds good John.  How is the braking combo?
« Reply #49 on: December 02, 2009, 05:47:49 pm »
The brakes are still marvellously strong.
Looks like I'll need some new rotors by Spring though as they are pretty worn.
How's yours?
Offline QD MBE
  • -Receive: 102
« Reply #50 on: December 02, 2009, 05:50:21 pm »
Like hitting a brick wall when pressed with meaning.
Very nice look too.  The grip/abs is the limit now...................  In the dry!
« Reply #51 on: December 02, 2009, 05:55:02 pm »
You need uprated track tyres for summer then  :happy2:
My R888's grip like a limpet under heavy braking
Offline Phil@BSH
« Reply #52 on: December 02, 2009, 06:48:34 pm »
Oh, and the 'settling' question? Will any Grrrr lessen? Or only as the bush becomes softer?
This customers review should help you get the best answer.
http://forums.vwvortex.com/zerothread?id=4609947&postid=62268774#62268774
513 bhp at 24 psi. More still to come!
BSH Speedshop
info@bshspeedshop.com
Help us work with you. If we make a part that you want and it needs special Euro fitments please contact tech@bshspeedshop.com
« Reply #53 on: December 02, 2009, 07:47:36 pm »
Thanks for the link, Phil.
As I thought, and would have hoped if I was buying BSH mounts - Pretty much the same extent of and occurrences of minor vibrations and 'noise' as the VWR and VF mounts.
Offline QD MBE
  • -Receive: 102
« Reply #54 on: December 02, 2009, 09:45:18 pm »
Minor......................??????????????????????????
« Last Edit: December 02, 2009, 11:28:20 pm by stokeballoon »
Offline Janner_Sy
  • -Receive: 113
« Reply #55 on: December 02, 2009, 10:07:03 pm »
You have the same thoughts as me, i want to remove the slack in the drivetrain etc and these side mounts do that great, but same as you i dont mind a bit of noise, but i dont want the car vibrating all the time.
would have been gutted to have bought it and found they were to much for me.
they are a bargain though? so when i get a second car ill be interested then.
Offline QD MBE
  • -Receive: 102
« Reply #56 on: December 02, 2009, 10:17:30 pm »
Sy,
I think the way to go would be to modify the OE mounts.  something I will look at soon.  This review is an open and honest account of my thoughts.  I have driven the VWR red car at length, and now the BSH mounts fitted to mine, and I feel they detract away from the ethos of a Golf GTI.  The understated slightly refined Golf is what it is about for me.  Just the trans play....................
I could have bought a Westfield if i wanted out and out pure attachment to the road.  I set out not to blow sunshine up the aris of the manufacturers, nor to be psychophantic in my review or posts.
« Last Edit: December 02, 2009, 10:27:23 pm by stokeballoon »
Offline Janner_Sy
  • -Receive: 113
« Reply #57 on: December 02, 2009, 10:30:17 pm »
interested to see how to mod the std mount. is it cost effective. or an easyish job, in comparison with swapping mounts
Offline QD MBE
  • -Receive: 102
« Reply #58 on: December 02, 2009, 10:34:27 pm »
Don't know.............  will do soon.  The mount has an oil filled bladder inside, so my aim is to slit this, clean it out and have a play...........
Offline Janner_Sy
  • -Receive: 113
« Reply #59 on: December 02, 2009, 10:37:52 pm »
look forward to that.
i heard a co-agulated mixture of rhino sperm and donkey saliva  is the way forward.
look
