November 18, 2024, 01:11:39 am
All Things Mk5
Mk5 General Area
Diverter Valve - Replace
Topic: Diverter Valve - Replace (Read 2937 times)
Rich
Just look at my post count
-Given: 7
-Receive: 8
Buy Land, They Don't Make It Anymore
November 28, 2009, 08:45:31 pm »
Someone told me that when reflashing your GTi, the diverter valve has the tendency to go a lot - is this true ?
They said it would need replacing around 1'ce a year - i didnt quite believe it
Your thoughts please...
Top Cat
Top cat
-Given: 171
-Receive: 335
Almost Jacamo
Re: Diverter Valve - Replace
Reply #1 on:
November 28, 2009, 08:48:02 pm »
My thoughts are try the search function.
If you managed to miss the 10,000 threads on this subject then you deserve to trawl through them all.
SteveP
-Given: 117
-Receive: 340
Reply #2 on:
November 28, 2009, 08:48:10 pm »
Have a search Rich the new rev D piston type and older rev G DV's have been discussed quiet a bit.
I ran the OEM rev G version on mine remapped for 40k+ miles with no problems (yours will have the same version fitted I would expect).
Edit - TC beat me to it
NB07
Won't Shut up.
-Given: 15
-Receive: 26
Reply #3 on:
November 28, 2009, 09:34:02 pm »
im still running mine from factory on 07 think its C and its fine. its one of those things that if you notice a problem then check it and replace but as has been said what aint broke dont need fixing
Hedge
-Given: 484
-Receive: 304
Reply #4 on:
November 28, 2009, 09:56:43 pm »
Personally speaking I think the K04 cars are much more sympathetic as the DV is not bolted into the turbo.
All Things Mk5
Mk5 General Area
