Author Topic: URGENT! cruise stalk problem  (Read 1821 times)
Offline K9
  • VW LifeStyle
« on: March 15, 2015, 04:21:05 pm »
got everything fitted and coded steering sensor etc. but can't get the cruise controller to work no green light etc!
specs: NO mfsw, no paddle shifters. dsg. anyone help pleaseee
@Eddie-NL  @vw55raz @th3_f15t
« Last Edit: March 15, 2015, 05:40:36 pm by K9 »
Offline K9
  • VW LifeStyle
Re: URGENT! cruise stalk problem
« Reply #1 on: March 15, 2015, 05:39:25 pm »
EDIT: when entering VCDS Engine ( 1 ) i can't access login or anything like that  :confused: only coding and security access
Offline doylebros
« Reply #2 on: March 15, 2015, 06:02:18 pm »
Take time to read this thread:-
http://www.mk5golfgti.co.uk/forum/index.php/topic,35449.0.html
Have you changed your steering controller- do you have the correct slip ring - do you need the diagnostic wire etc.
Near the end of the thread it shows the coding for there set up!
« Last Edit: March 15, 2015, 06:09:52 pm by doylebros »
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #3 on: March 15, 2015, 06:03:31 pm »
If you have a GTI you shouldn't need to replace any controllers. What model is yours?
Offline K9
  • VW LifeStyle
« Reply #4 on: March 15, 2015, 06:03:48 pm »
Have you change your steering controller- do you have the correct slip ring - do you need the diagnostic wire etc.
@doylebros i have the midline crontroller so the CC option was in VCDS
Offline K9
  • VW LifeStyle
« Reply #5 on: March 15, 2015, 06:04:18 pm »
@GrayMK5GTI Midline
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #6 on: March 15, 2015, 06:05:02 pm »
Sorry fella I meant what car do you have (GTI, SE, TDI etc. . )
Offline K9
  • VW LifeStyle
« Reply #7 on: March 15, 2015, 06:09:21 pm »
@GrayMK5GTI golf mk5 gti 2005 dsg. midline cluster. none mfsw. no paddles.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #8 on: March 15, 2015, 06:12:20 pm »
My old GTI and my Ed30 were midline with manual gearbox and cruise coded in no problems.
From what I read it should all code in fine on any GTI  :surprised:
Offline K9
  • VW LifeStyle
« Reply #9 on: March 15, 2015, 06:14:17 pm »
what all should be coded? when i see pics the people go to engine (1) and press "login" and enter a number guess it was 11642? but mine don't say Login. :( and what should i put in steering wheel selection? the (7) number long code 0000000
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: March 15, 2015, 06:21:46 pm »
as you have a gti it doesn't have a log in
coding will be in the long coding
Cluster and Key coding
Location Great Yarmouth
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Offline K9
  • VW LifeStyle
« Reply #12 on: March 15, 2015, 06:42:27 pm »
heres my scan that i made now.
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ5P068249   Mileage: 82220km-51089miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 A    HW: 1K0 907 115 A
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E1453421
   Coding: 040300031C070160
   Shop #: WSC 11400 205 78078
   VCID: 2447CEADE7CEC9012A8-8071
2 Faults Found:
001384 - Cruise Control Switch (E45)
               P0568 - 002 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 82222 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 02:27:08
             Freeze Frame:
                    RPM: 1871 /min
                    Load: 41.2 %
                    Speed: 49.0 km/h
                    Temperature: 60.0*C
                    Temperature: 22.0*C
                    Absolute Pres.: 1040.0 mbar
                    Voltage: 14.224 V
049412 - No Communication with Cruise Control Module
               U0104 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 82225 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 02:39:48
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 64.0*C
                    Temperature: 28.0*C
                    Voltage: 12.192 V
Readiness: 0000 0101
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 042 M    HW: 02E 927 770 AD
   Component: GSG DSG         041 0824
   Revision: 04004010    Serial number: 00000501040307
   Coding: 0000020
   Shop #: WSC 00028 028 00001
   VCID: 1D31FB49C4A4F8C9656-8048
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0004738
   VCID: 3A7B10D5754AAFF1604-806F
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AC
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
   VCID: 68DF9A9D5B66ED61C60-803D
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001373004
   Coding: ED8F8F1600040014001400001400000000187F075C
   Shop #: WSC 12345 123 12345
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00218142
   Shop #: WSC 12345
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
   Component: 07 AIRBAG VW8   013 2100
   Revision: 02013000    Serial number: 0033HD04WMGO
   Coding: 0012343
   VCID: 2C57268D8F1E0141E28-8079
   Subsystem 1 - Serial number: 6332MSME08360305$
   Subsystem 2 - Serial number: 6342MSME07764B09G
   Subsystem 3 - Serial number: 6351HSME06075705/
   Subsystem 4 - Serial number: 6361HSME06154A0C6
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 021 0050
   Coding: 0010042
   VCID: 356103E95C5440898D6-8060
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 860 E
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0007103
   Shop #: WSC 31245 001 1048576
   VCID: 306F32FDA33665A1DE0-8065
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AL    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1642
   Revision:   H58       Serial number: 010414F1001837
   Coding: 350002
   VCID: 7AFBD0D5F5CA6FF1204-802F
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0812
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0119
   Coding: 0000052
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.12      1502
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 80C802087F2D8404084F01E010
   VCID: 7BF5D5D13AF056F93B2-802E
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 316937F9A83C6CA9D1E-8064
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 H    HW: 3C8 035 195 H
   Component: Radio RCD510  005 0244
   Revision: 00000001    Serial number: VWZ1Z3M8114673
   Coding: 01000400040005
   Shop #: WSC 00066 123 12345
   VCID: 2D512B8974040849F56-8078
1 Fault Found:
02877 - Digital Radio Antenna (R183)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 70
                    Mileage: 82222 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 02:25:12
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0217
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
End-------------------------(Elapsed Time: 01:43)--------------------------
@Eddie-NL  any ideas?
« Last Edit: March 15, 2015, 07:04:10 pm by K9 »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #13 on: March 15, 2015, 07:50:54 pm »
does your car have a roof antenna?
if not the you need a wire
Offline K9
  • VW LifeStyle
« Reply #14 on: March 15, 2015, 08:06:19 pm »
nope. it has the antenna in the back window i guess. nothing on roof.
EDIT: if you'r talking about the radio fault code then that's not what conserns me now  :innocent:
