Author Topic: Eibach Sport Line DSG (Sorted!)  (Read 3823 times)
Offline BenMiller692
Re: Eibach Sport Line DSG
« Reply #15 on: April 16, 2015, 05:58:29 am »
I assume the springs are harder for the heavier DSG gearbox?
Offline basman
« Reply #16 on: April 16, 2015, 08:14:24 am »
Whats the difference with the DSG ones?
rears are the same but front are designed to take more weight hence the car sitting lower
Offline LUCKO
« Reply #17 on: April 16, 2015, 11:34:09 pm »
what happens if you fit dsg springs to manual would it level out the drop?
apparently spring kit makes front sit lower than rear....
Offline samiul11
« Reply #18 on: April 17, 2015, 10:58:32 am »
So the car sits lower at the front with the dsg springs? Sounds tempting but i've got a manual?
Offline Phil_H
« Reply #19 on: April 17, 2015, 12:00:47 pm »
On a DSG car if you fit "Non DSG" springs it's sits lower on the front due to the different spring rate.
DSG gearbox is quite a bit heaver than a manual. If you fit DSG springs to a Manual it will more than likely sit higher.
Offline Phil_H
« Reply #20 on: May 11, 2015, 09:27:22 pm »
So...finally got round to putting my DSG Springs on the front...
Also treated the car to some new Sach's struts as the passenger one was a little bouncy over pot holes.
Car now sit's pretty much level all the way round, much more OEM :)  (will get a decent pic up)
from hub centre to arch lip is 34mm all round now.
 :pomppomp:
Offline Phil_H
Re: Eibach Sport Line DSG (Sorted!)
« Reply #21 on: May 12, 2015, 09:50:28 pm »
Offline Vwgticrazy
  • -Given: 41
« Reply #22 on: May 13, 2015, 02:27:25 am »
Can you tell any difference in comfort than standard springs.
Offline Phil_H
« Reply #23 on: May 13, 2015, 12:34:24 pm »
Bumpy roads around Norfolk don't seem to be an issue. My misses has a BMW Mini and thats far worse on it's standard suspension :)
