Author Topic: Steering wheel cowl noise!  (Read 2422 times)
Offline galaxie500
  • -Given: 38
  • 56 plate 5 door in Black Pearl Metallic
« on: March 19, 2015, 11:09:46 pm »
Very annoying rattle which seems to be coming from just below intrument cluster within the steering wheel cowl. When the rattle 'rattles' a slight pressure on top of the cowling stops the noise.
Anybody else suffering similar and any solutions? Should I remove cowling to investigate?
PR
Offline galaxie500
  • -Given: 38
Re: Steering wheel cowl noise!
« Reply #1 on: March 20, 2015, 08:21:26 pm »
Anyone suffering similar please!! It's driving me crazy. And not in a good way!
Offline GTIEagles
« Reply #2 on: March 20, 2015, 09:43:27 pm »
Are the clips which attach the top cowling to the bottom there? I had an annoying rattle and one of the clips was missing, got a new one from vw for about 20p and problem solved!
Offline galaxie500
  • -Given: 38
« Reply #3 on: March 20, 2015, 11:42:41 pm »
Thanks for your reply cnut; I've never had the cowl apart. Is it an easy job?
PR
Offline GTIEagles
« Reply #4 on: March 20, 2015, 11:52:38 pm »
The top one just unclips off. Pull the wheel out towards you and using a credit card or something thin but strong place it between the two cowlings and prise it apart. 30 sec job.
Offline galaxie500
  • -Given: 38
« Reply #5 on: March 20, 2015, 11:58:26 pm »
I'll be having a look first thing in the morning! Thanks again.
PR
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
« Reply #6 on: March 21, 2015, 04:42:58 pm »
Mine does the same. I took the cowling off and did up some screws on the cluster. Then used Vaseline around that plastics that's not visible and it did kinda do the job. I have many other rattles now, the biggest is from the glove box. It sounds like a screw has become lose.
It doesn't help when you got solid mounts and your front shocks are knackered when it's cold!
Offline galaxie500
  • -Given: 38
« Reply #7 on: March 21, 2015, 07:11:09 pm »
I split the cowl top and bottom as instructed ( thanks!) and nothing missing clip wise so I guess noise is down to creaky old age, like me!
I may carefully apply some lube to the joints and see what happens.
PR
