Author Topic: DAB Windscreen Antenna  (Read 8473 times)
Offline Lyons
  • -Given: 18
« on: March 20, 2015, 11:59:46 am »
These have been out for a while now and I'm wondering if anyone can give some feedback on what they're like? I've read some reviews of them not being great a couple of years ago, but wondered if things have improved in recent times?
I know the OEM 6R0035501D is cheap enough, but I could just do without the hassle of installing it if the windscreen antennas were up to the job instead.
Offline paulw123
  • -Receive: 47
Re: DAB Windscreen Antenna
« Reply #1 on: March 20, 2015, 04:36:55 pm »
Had the best rated one from dabonwheels, and it kept dropping out for 1/2 of my daily commute.
Fitted vw polo roof aerial and no problems at all.
I guess if you live under the DAB transmitter you'll be ok  :signLOL:
Offline galaxie500
  • -Given: 38
  • 56 plate 5 door in Black Pearl Metallic
« Reply #2 on: March 20, 2015, 04:53:09 pm »
I fitted a windscreen mounted DAB aerial before Xmas and was happy enough but it has recently been losing signal more frequently. The prospect of pulling the headlining, passenger seat and associated trim isn't particularly pleasant but I reckon the time will come shortly. Good luck!
Offline paulw123
  • -Receive: 47
« Reply #3 on: March 20, 2015, 04:58:48 pm »
If you replace the roof aerial, its not too bad. On a 5door the cable can be tucked under door rubbers and then down A pillar.
Offline Lyons
  • -Given: 18
« Reply #4 on: March 21, 2015, 06:36:48 am »
I read an older thread that mentioned the base/fixings of the Polo aerial were different to the hole left when the standard aerial is removed.
Offline Lyons
  • -Given: 18
« Reply #5 on: March 21, 2015, 06:39:56 am »
Hmm mine is a 5 door, so it's easy enough? Which part number did you go for? Am I right in thinking there are connections for nav, FM and dab, therefore 3 extension cables need run down to the RNS?
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
« Reply #6 on: March 21, 2015, 09:34:59 am »
This could well have been my post, I bought the 2015 model year Polo aerial and it has a different base as detailed here:
http://www.mk5golfgti.co.uk/forum/index.php/topic,84892.45.html
So the best option is to go for the previous version of the Polo aerial...
Part number: 6R0 035 501 A
Offline Lyons
  • -Given: 18
« Reply #7 on: March 21, 2015, 11:37:12 am »
It was indeed you. So did you end up swapping it for this 1? And it fits perfectly?
Are the 2 wires there for FM and dab?
What extension cable did you use?
Offline paulw123
  • -Receive: 47
« Reply #8 on: March 21, 2015, 02:56:19 pm »
Yeah if you have RNs I'd get the one linked in 1st post, ebay Germany is cheapest.
You're original FM cable stays for FM, but you'll need a 3 new cables for phone, GPS, DAB if you want all 3.
I think the other FM for diversity comes from somewhere else, under seat or hatchback? haven't come across it yet. You'll need an FM dual fakra conversion lead at head unit end about £8 ebay.
I still have the window DAB stick on one, if someone wants to pay the postage, you can have it and try your areas signal....
Fitting in 5door was really easy, just don't force the headling too much, but it will bend enough to get the cable under, just remove the airbag plastic labels on pillars and the screw underneath. Worst bit was working upside down on the aerial and disconnecting the old FM cable, a mirror might help, but in the end I yanked on the white plug with some pliers and it came free.
Offline Lyons
  • -Given: 18
« Reply #9 on: March 21, 2015, 03:03:46 pm »
Ah, I forgot there's already be an FM 1 running up there for the standard radio!
I'll only need one for the DAB then as the RNS I've bought comes with a GPS antenna that'll be good enough for me. Is this the exact cable I'll need; http://m.ebay.co.uk/itm/161607245570?nav=WATCHING_ACTIVE
I can't see any of the antennas on ebay anywhere.
Offline Golf_GT_TDI
  • -Given: 45
« Reply #10 on: March 21, 2015, 04:06:09 pm »
Yeah that's the cable. At present I've decided against modding the roof although I did make a template, if I had the headlining to still swap out I'd do it so I'll go via the 6R0 route
Offline Lyons
  • -Given: 18
« Reply #11 on: March 21, 2015, 05:12:13 pm »
Woukd you not sell the 6C0 unit and get a 6R0 one?
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #12 on: March 21, 2015, 05:17:55 pm »
I have the windscreen antenna and intend on fitting it tomorrow, if it doesn't perform i will be retrofitting the DAB+ antenna in the boot lid.
Offline Golf_GT_TDI
  • -Given: 45
« Reply #13 on: March 21, 2015, 07:45:37 pm »
I will probably just been busy and not got round to sorting an advert as yet.
Offline Lyons
  • -Given: 18
« Reply #14 on: March 22, 2015, 08:15:07 am »
Just to confirm, is a fakra cable a standard thing? Do the FM and DAB plugs have the same connections?
I assume Ill still need the double to single adapter for the FM on the back of the RNS?
