Author Topic: Fuse information  (Read 13652 times)
Offline snapey
Fuse information
« on: November 29, 2009, 05:54:39 pm »
Hi chaps, Hopefully this will come in handy for someone in the future having difficulty with electrical problems that 9 out of 10 are fuse related. There doesn't seem to be a definitive list anywhere of the fuse numbers and what part of the vehicle they protect along with the fuse rating. All of the information is taken from the mk5 Haynes manual and is listed for the 1.6 engines but I can't see any reason why any harnesses would be different between the two engines.
Passenger compartment fuse box
F1 - Diagnostic connector, fuel pump, ECU - 10A,
F2 - Brake pedal switch, ABS control unit - 5A,
F3 - Instrument control unit - 5A,
F4 – Reversing light switch, oil level / temp sensor, tyre pressure monitor switch, traction control switch – 5A,
F5 – Headlamp levelling (halogen), Headlamp range control unit (gas discharge) – 5A,
F6 – Diagnostic control unit, power steering, tiptronic switch, instruments – 5A,
F7 - Anti dazzle interior mirror – 5A,
F8 – Four-wheel drive control unit, trailer detector control unit – 5A,
F9 -
F10 -
F11 -
F12 – Drivers door / passenger door control unit – 10A,
F13 – Light switch, break switch, diagnostic connector – 10A,
F14 – Auto six speed gearbox – 5A,
F15 – Onboard supply control unit – 7.5A,
F16 – Heater switch – 10A,
F17 – Rain / light sensor, aerial selection unit (radio) – 5A,
F18 – Double clutch gearbox, selector level sensor control box, tiptronic switch (six speed gear box) – 5A,
F19 -
F20 – ABS control unit – 5A,
F21 -
F22 -
F23 – Drivers door / passenger door control unit – 30A,
F24 – Cigar lighter (Nov 05 on) – 25A,
F25 – Fresh air blower relay – 25A,
F26 – 12V socket (luggage compartment) – 20A,
F27 – Fuel pump control unit – 15A,
F28 – Cigar lighter (to Oct 05) – 20A,
F29 – Crank breather heater, air mass meter – 10A,
F30 -
F31 – Brake vacuum pump – 20A,
F32 – Electronic window lifts, rear door control unit – 30A,
F33 – Sunroof control unit – 25A,
F34 -
F35 – Alarm horn, vehicle inclination sensor, interior monitor sensor – 5A,
F36 – Headlight washer – 20A,
F37 – Heated front seats control unit – 30A,
F38 -
F39 – Auto six speed gearbox control unit – 20A,
F40 – Heater switch – 40A,
F41 – Rear wiper motor – 15A,
F42 – Onboard supply control unit – 15A,
F43 – Trailer detector control unit – 15A,
F44 – Trailer detector control unit – 20A,
F45 – Trailer detector control unit – 15A,
F46 – Heated washer jets (optional), heater switch – 5A,
F47 – Aux heater relay – 5A,
F48 -
F49 – Light switch – 5A,
Engine compartment fuse box
F1 – Convenience system control unit – 20A,
F2 – Steering column control unit – 5A,
F3 – Onboard supply control unit – 5A,
F4 – ABS control unit – 30A,
F5 – Mechatronic unit (DSG) – 15A,
F6 – Onboard supply control unit – 5A,
F7 –
F8 – Radio – 15A,
F9 – Phone control unit – 5A,
F10 – ECU (petrol) – 25A,
       - Terminal 30 supply relay drive (diesel),
F11 – Aux heater control unit – 20A,
F12 – Diagnostic control unit – 5A,
F13 – ECU (petrol) – 25A,
       - ECU (Diesel) – 30A,
F14 – Ignition coil – 20A,
F15 – Starter relay (diesel) – 40A,
F16 – ABS control unit – 30A,
F17 – Onboard supply control unit – 30A,
F18 – Sound system – 30A,
F19 – Wiper motor control unit – 30A,
F20 –
F21 – Lambda probe – 15 A,
F22 – Clutch position sensor – 5A,
F23 – Fuel regulator valve – 15A,
       - Exhaust gas recirculation cooler changeover valve – 10A,
F24 – Intake manifold flap valve, charcoal filter solenoid valve – 10A,
F25 – Onboard supply control unit – 40A,
F26 – Onboard supply control unit – 40A,
F27 – Glow plugs control unit – 50A,
F28 – Term 15 supply – 40A,
F29 – Distribution to passenger fuse box – 50A,
F30 - Onboard supply control unit – 40A,
Fuse box on the side of the main engine fuse box
F1 – Alternator – 150A/200A,
F2 – Power steering – 80A,
F3 – Rad fan control unit – 50A,
F4 – Optional equipment – 40A,
F5 –
F6 – Supply distribution to passenger fuse box – 80A,
F7 –
Hopefully some of the information will come in handy for someone in the future.
Luke
« Last Edit: February 02, 2011, 03:30:55 pm by snapey »
If you have to ask why, you'll never understand.
Jaymejump
Re: Fuse information
« Reply #1 on: April 16, 2015, 01:15:51 pm »
That's just what i was thinking.
Offline btowery
« Reply #2 on: April 28, 2015, 12:31:07 am »
BEWARE. VW makes a habit of changing fuse locations. Even the same engine codes sometimes have wandering homes for fuses.
