Author Topic: Scary revo 1 settings!!  (Read 10145 times)
Offline jacobrownoly
« on: March 21, 2015, 12:48:49 am »
Hey, had my mk5 gti mapped to revo stage 1 at B9 T5 F5 car felt great but wanted to run the figures past Revo directly and they pretty much said that the settings could end up hurting my car as I only have the standard fuel pump on :surprised:. They said it was pretty rare to see figures like that for stage 1.
I told them i had a revo intake on and only use v-power so they suggested i go to B7 T5 F9, which I did with my SPS switch (great bit of kit btw) (Apparently Fuel should be leave on 9 unless u have a uprated fuel pump)
I changed the settings two days ago but I don't really feel much difference. The boost maybe does feels more progressive as I have taken it down to 7. (The car still feels great)
So my question is, does it take time for the ECU to adapt again to an SPS setting or should it be pretty much instant??
Also, if you have the SPS switch how good/healthy is it for the ECU to keep changing setting, say if you just wanted to mess around with different settings?? Surly I can't be good for it.
p.s - Out of the B, T, F setting which one is more to do with BHP??
Thanks :happy2:
« Last Edit: March 21, 2015, 12:52:08 am by jacobrownoly »
Offline DomBacon
Re: Scary revo 1 settings!!
« Reply #1 on: March 21, 2015, 02:27:27 pm »
What sps switch you using?
« Reply #2 on: March 21, 2015, 03:59:07 pm »
The newer one i think, i works with the SPS+ software. Why do u ask?
Offline DomBacon
« Reply #3 on: March 21, 2015, 04:02:17 pm »
Just wondering as the old one which is what I've got you can't adjust the settings
I've been to 2 revo dealers and they have both changed my settings around so I don't know what one to trust!
How do you do the logging yourself?
« Reply #4 on: March 21, 2015, 07:27:52 pm »
Get yourself the newer switch, i got mine on ebay for £75. Great bit of kit! U can then download the software from revo and mess around with some setting. Although most people will say to get the car logged first
I haven't had the car logged....i just told revo the setting which was b9 t5 f9 and they said it was rare and almost dangerous to ran at that setting for stage 1.
I set the car using my SPS for b7 t5 f9 which revo suggested and the car still feels really good, not noticed too much of a difference yet.
« Last Edit: March 21, 2015, 07:30:17 pm by jacobrownoly »
Offline DomBacon
« Reply #5 on: March 21, 2015, 08:52:11 pm »
What you got the sps plus switch for £75?!
« Reply #6 on: March 21, 2015, 09:04:36 pm »
Well £77 lol. Ebay is your friend ;)
Offline DomBacon
« Reply #7 on: March 22, 2015, 12:40:31 am »
What a bargin! There like £300!!!
I'll keep my eye out for one  :happy2:
Offline bigeyd
  • -Receive: 31
« Reply #8 on: March 22, 2015, 07:54:03 am »
I personally would not bother with logging,the sensor is not in the original housing so the readings will not as accurate,also a dyno is only good if you do it like in laboratory conditions as in everything is done exactly the same before and after,but it is good for pub ammo if your figures are high :)
I would lower the Fuel settings to see any difference but bear in mind when comparing it leave it an hour or so depending on how spirited your driving.Heatsoak is a bitch
« Reply #9 on: March 22, 2015, 11:57:23 am »
I was thinking about lowering the setting from 9 to 8 for the fuel. My dad was saying the other day that if ur fuel is too lean it also can damage the engine. I ll maybe drop revo an email to see if that would be ok with the standard fuel pump.
Is it more beneficial for the fuel to be richer??
Offline bigeyd
  • -Receive: 31
« Reply #10 on: March 22, 2015, 01:29:09 pm »
I would drop their support an email,I changed mine from their settings after tweaking it on a dyno.
Offline DomBacon
« Reply #11 on: March 23, 2015, 05:47:41 pm »
I just got off the phone to revo
The lower the number the leaner it is! The higher the number the richer it is!
Boost 8, timing 4/5, fuel 9
Offline xjay1337
  • -Receive: 377
« Reply #12 on: March 23, 2015, 05:51:25 pm »
My stage 2 revo was B7 F8 T4 or something like that.
Offline DomBacon
« Reply #13 on: March 23, 2015, 10:31:59 pm »
My stage 2 ed30 is b9 t5 f8
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #14 on: March 24, 2015, 07:54:45 am »
F9 is lean, not rich. I suggest you speak to one of the technical team as opposed to the sales staff.  F9 on my car yielded an actual AFR in the high 12's as verified on a RR using an independant wideband AFR.
It is only a target AFR though, EGT protection routeine will dump plenty of fuel and give you a very rich mixture if it gets too hot. Why not check it yourself, run it at F9, then log specified and actual Lambda, then try F2 and log specified and actual Lambda again.
Got to love Meth though, being able to run the Boost at 9 and Timing at 7 at Stage 2+
