Author Topic: Scary revo 1 settings!!  (Read 11667 times)
Offline DomBacon
Re: Scary revo 1 settings!!
« Reply #15 on: March 31, 2015, 12:55:13 pm »
I spoke to one of the technical people for about 20 mins about everything haha
Offline Flaffy
« Reply #16 on: May 04, 2015, 06:33:30 pm »
You must have misundestood the tech, as a higher number aims for a leaner mixture. For the standard hpfp the general opinion seems to be that You should not take the fuel setting below 8... lower(richer) than that, You need an upgraded hpfp, like Autotech..
Best Regards
Anders T
Mk5 Gti DSG 2005
Offline jasam
  • My Ride: 2.0 tfsi k04, revo stage 3
« Reply #17 on: March 10, 2016, 08:46:53 pm »
F9 is lean, not rich. I suggest you speak to one of the technical team as opposed to the sales staff.  F9 on my car yielded an actual AFR in the high 12's as verified on a RR using an independant wideband AFR.
It is only a target AFR though, EGT protection routeine will dump plenty of fuel and give you a very rich mixture if it gets too hot. Why not check it yourself, run it at F9, then log specified and actual Lambda, then try F2 and log specified and actual Lambda again.
Got to love Meth though, being able to run the Boost at 9 and Timing at 7 at Stage 2+
how much maf g/s you have without meth (on higher settings) and how much g/s have with meth and timing 7?
I thinking about meth lately
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #18 on: March 10, 2016, 09:16:24 pm »
Not logged with vs without, I now run the timing on T9 so wouldn't try that without the meth. MAF reading would probably be unchanged as the boost pressure wouldn't change. Peak g/s reading 235 when very cold outside, usually around the 225-230 mark
Offline jasam
« Reply #19 on: March 10, 2016, 11:04:02 pm »
ok, thats g/s without meth?  good for stage 2+
