Author Topic: Kufatec Heated seat wiring loom  (Read 4906 times)
Offline ollie288
« on: November 29, 2009, 09:41:34 pm »
Has anybody installed the above? If so im in desperate need of help as my car has had the trim removed for the last month or so waiting for the wires to be connected.
I have routed the wire and it is connected under the seats.
I have also fitted a new climate unit with heated seat switches and wired that the only thing left is the fuse box and center electrics module (I think thats the name)
If anyone knows the answers due to having fitted it or just superhuman knowledge then please let me know!
Kufatec have abandoned me and say they cant help which is great! :fighting:
Mortygttdi has been very helpful and has suggested locations but he is not 100% sure so if someone could confirm this please do so.
It would be great to get the inside of my car back together!
Ollie :happy2:
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Kufatec Heated seat wiring loom
« Reply #1 on: November 29, 2009, 11:11:26 pm »
You have a PM mate.  :evilgrin:
Stu...
Offline mortygttdi
  • -Receive: 146
« Reply #2 on: November 29, 2009, 11:25:41 pm »
Ollie what ever info you get would be best to collate it all and bang it up on the forum,  for others to go by, has you know its been hard to get the info and if any one else is thinking of doing it you can make there life easier.
I certainly will be doing when I find some RS4 seats :happy2:
Darren
Offline ollie288
« Reply #3 on: December 05, 2009, 10:41:17 pm »
Darren
I will do but my info on this is very low at the min!
Anybody else have any ideas?
Offline mortygttdi
  • -Receive: 146
« Reply #4 on: December 14, 2009, 01:41:32 am »
Under Driver’s Seat Connector
Pin 1 – Thin white wire.
Pin 2 – Thin blue and yellow wire.
Pin 3 - Thick red and white wire.
Pin 4 – Thin grey wire.
Pin 5 – Thick brown wire.
Pin 6 – Empty
Pin 7 – Empty
Pin 8 – Thin grey wire which is a direct link to pin 9 on same connector.
Pin 9 – Thin grey wire which is the link to pin 8 and a thick grey wire in as well.
Pin 10 – Empty
Under Passenger’s Seat Connector
Pin 2 – Thin blue and red wire.
Pin 6 – Empty
Pin 7 – Empty
Pin 10 – Empty
Behind Climatic unit
This has three wires going to it: This is different with lumber support
Thin Blue and yellow wire – going to pin 15 of the 20 pin connector.
Thin blue and red wire – going to pin 11 of the 20 pin connector.
Thin grey – going to pin 16 of the 20 pin connector.
I have connected this myself as said by the kufatec instructions.
Ground
Thick brown wire – connected to earth point on drivers side at bottom of a pillar.
Wires I have left to connect to fuse box and Central electrics module
Thick red and white wire. Red/Yellow SC37 fuse box
Thick grey wire. S44 central electrics its number 1 relay at the front?
Thin grey wire. SC34 fuse box
Double black wire connected together with one crimp. im not right sure with this
Double white wire connected together with one crimp. C-1 central electrics
