Author Topic: 14 mm Spline tool - help!  (Read 12312 times)
Offline samb377
Offline andybon
Re: 14 mm Spline tool - help!
« Reply #16 on: March 23, 2015, 08:26:03 pm »
I did mine without removing the carrier, just had to shimmy them around and off they came.
How hard can it be?
Offline Jarre
« Reply #17 on: March 24, 2015, 11:04:52 am »
Do you know how much this cost Mike?
Candy White ED30 :)
« Reply #18 on: March 24, 2015, 11:20:32 am »
I'll look through my receipts for you
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
« Reply #19 on: March 24, 2015, 03:19:13 pm »
It's made by Snap-On for VW costs around £13
« Reply #20 on: March 24, 2015, 04:59:17 pm »
Been out all day. £18 rings a bell.
Offline Stamanatic
« Reply #21 on: March 24, 2015, 05:03:52 pm »
I'd seriously recommend buying the Halfords spline kit, top quality, I put the 14mm spline bit under serious pressure and not a mark on it. Was gutted at first having to buy a whole set for one piece, but wow what a quality kit.
Offline paulw123
  • -Receive: 47
« Reply #22 on: March 24, 2015, 05:43:03 pm »
^^^ x 2
I've got the Halfords spline kit as well, expensive, but good quality, and not much choice on a sunday afternoon  :sad1:
Offline Stamanatic
« Reply #23 on: March 25, 2015, 12:03:48 am »
On a Sunday it's your saving grace haha.
Offline Jarre
« Reply #24 on: March 25, 2015, 11:33:18 am »
I have the halfords one but with my torque wrench space is extremely tight, we've had the tool stuck on a number of occasions haha
Candy White ED30 :)
Offline SI-R32
  • -Receive: 125
« Reply #25 on: March 25, 2015, 01:00:38 pm »
i have both the halfords one and the proper vw one, its doable with the halfords one especially as you don't have rear drive shafts on your gti's, however its easier with the vw one no matter what mk5 golf you own.
good luck undoing them if your only on axle stands as the hight needed to get the purchase on the breaker bar can be a problem with the ridiculous tightness vw do these up, plus throw in a bit of rust and corrosion and you'll be needing a swear jar pretty soon
« Last Edit: March 25, 2015, 01:08:15 pm by SI-R32 »
Offline Jarre
« Reply #26 on: March 25, 2015, 01:04:04 pm »
Indeed. I've only ever done it on axle stands and it requires patience :)
Candy White ED30 :)
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #27 on: March 25, 2015, 05:46:36 pm »
There's definitely a knack to the angle whilst on the drive way... a nice mixture of Auto Trans fluid / Acetone makes the break torque a lot less for the bar on those splines, but they are hefty buggers and can take some punishment. :D
