Author Topic: Puddle light question from Newby  (Read 909 times)
Offline toplad
« on: March 24, 2015, 10:47:19 pm »
Hi
Need to replace the puddle light on my pax side, quick scan on ebay shows a few. Are puddle lights LED as standard?
I don't want one as LED and the undamaged one a different brightness or colour?
« Last Edit: March 25, 2015, 07:50:28 am by GrayMK5GTI »
Offline toplad
Re: Puddle light question from Newby
« Reply #1 on: March 25, 2015, 07:25:19 pm »
Does no one know the answer to this?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #2 on: March 25, 2015, 07:37:03 pm »
The OEM bulb is a simple w5w bulb. I recommend getting the full led version as it's much brighter. If you want to keep the OEM look, any car shop should have what you need.
Offline toplad
« Reply #3 on: March 26, 2015, 09:49:23 am »
I only need to replace one side , so would rather just buy one to match OEM, but all seem to be LED on eBay
Offline paulw123
  • -Receive: 47
« Reply #4 on: March 26, 2015, 10:24:05 am »
Redemption
« Reply #5 on: March 26, 2015, 12:13:58 pm »
Offline toplad
« Reply #6 on: March 26, 2015, 07:10:58 pm »
I probably haven't worded this well, but it works fine. But the lens is cracked, that's the only bit I want to replace.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #7 on: March 26, 2015, 07:33:21 pm »
Can you check if you can identify the part number of the support. Should have one as it can be easily separated from the rest.
