September 21, 2024, 06:47:21 pm
All Things Mk5
How to Guides / Troubleshooting
Rear fog light not working??
Topic: Rear fog light not working?? (Read 4098 times)
kam
Won't Shut up.
-Given: 37
-Receive: 5
March 26, 2015, 12:59:38 pm »
Hi guys just to pick your brain I just took the car for an mot and it failed due to the rear fog light not working bulb is fine and everything else works in the rear ?
Been reading and some people have suggested a broken wire ? Could this be the case ? The car has a later mk6 silver tipped headlight switch would this make a difference . Oh and I had front fogs which were removed when I fitted the r32 front could the rear have been disabled when these were removed ??
Any help would be appreciated
Last Edit: March 26, 2015, 10:22:55 pm by kam
Flyingscotsman
Always Involved
-Given: 24
-Receive: 22
Re: Rear fog light not working??
Reply #1 on:
March 26, 2015, 06:10:57 pm »
Have you tried replacing the bulb?
kam
Won't Shut up.
-Given: 37
-Receive: 5
Reply #2 on:
March 26, 2015, 10:23:19 pm »
Bulb works fine
OSB
Always Involved
-Given: 32
-Receive: 17
Reply #3 on:
March 27, 2015, 04:20:15 pm »
Check fuse - not sure which one, but Google fuse layout.
If that is ok, check if 12v power is getting to the socket.
If not, then it could be the switch but probably wiring.
One of the weak wiring points is where the loom comes into the tailgate.
All Things Mk5
