Author Topic: Hissing brake servo  (Read 5927 times)
Hissing brake servo
« on: March 27, 2015, 11:08:31 am »
I understand a leaking brake servo is quite common the MK5 / 8P Audi A3, which causes an annoying hissing sound from the pedal area at low speeds and when idling.
Has anyone swapped the servo out themselves, or is it a ramp job because the engine has to be moved around a bit to get it out?
Re: Hissing brake servo
« Reply #1 on: March 27, 2015, 05:31:03 pm »
Usually it's a perished vacuum pump hose (as seen in the pic) that leaking and needs changing. Ignore the red circle in that pic.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #2 on: October 22, 2015, 01:59:30 pm »
What is that nipple for on the hose that is marked with a red circle around it ???
Silver is the way !
« Reply #3 on: October 23, 2015, 06:09:59 pm »
On a mk5, vw has a block off rubber piece for that nipple as the original earlier ones didn't have it.
As for why it's there, haven't got a clue...
Offline GTI07
  • Newbie
« Reply #4 on: October 28, 2024, 09:00:52 pm »
Hi does anyone know if a hissing servo will cause clutch pedal to drop now and again or not ? I’ve had new clutch flywheel slave cylinder and had it bled twice to make sure wasn’t just air some people say it’s my clutch. Master but some say hissing servo will cause it only drop like once every few days then is fine again get stuck like half way coming back up ?? Any help appreciate jt
